Hello everyone, thanks for taking the time to read this and respond.
I have come across a 1992 325ic that seems to have been neglected. I'm not exactly sure what has been done to it in the past, but I'm know not much has been done.
I've noticed that it takes around 8 cranks before the engine finally starts. The first thing I though was the check valve causing the fuel to leak back to the tank, so I let the car sit with the key in the "on" position for 30 seconds to let the fuel pump prime. I turned the key but the long cranking was still there. Next I thought fuel pressure, so I hooked up my trusty Snap-On gauge and jumped the fuel pump relay following the Bentley procedure. In a fraction of a second the gauge shot up to 300 kPa, or 143.51 psi, which according to the Bentley is damn near perfect. I let the gauge sit for 20 minutes and the pressure was still at 300, so for me this crosses out the FPR, fuel pump, check valve, and any sort of loss of pressure in the fuel system. Should I have let the gauge sit for longer than just 20 minutes?
I also checked compression, because the car seems to have a misfire when it gets hot, and the compression reads (from 1-6) in psi: 149, 160, 157, 150, 160, 160. I did all these as a dry compression test and I saw no reason to do a wet test since these read fairly good.
So what I'm thinking is that the car needs a new ignition system (cap, rotor, wires, plugs). Compression and fuel delivery are good so the only thing i can think of is the ignition system is poor.
I have also read about how messed up timing can be the cause of a long crank. Any thoughts on that?
So what I'm asking is if anyone has any knowledge or experience with this type of situation, can you please lend me some advise?
Also, if anyone has any ideas as to what would cause the misfire when the engine gets hot I would appreciate those ideas too.
I have cleaned the ICV and the entire throttle body and replaced the O2 sensor.
Thank you all so much!
Using Tapatalk
Do you have intake leaks?
That's a good question. I have been meaning to smoke test it but I just haven't gotten around to it.
I'm familiar with the method of spraying carb cleaner or brake cleaner all over as a way to test for leaks but I think it'd be more accurate to use a smoke tester. Do you know where a good spot for hooking the smoke machine up would be?
Using Tapatalk
The fuel system will not prime. Fuel pump is controlled by the ECU and it doesn't turn on the pump until it sees timing data from a cranking engine. However your other test with the gauge shows a leaky fuel system isn't likely the issue.
"Howdy, Folks!"
what do you actually mean when you state... "... it takes about 8 cranks before the engine finally starts ..." ,,, What is a crank..?
also, when you state that messed up timing might be the cause of a long crank ... how long do you have to crank this engine for it to start?
... forty-three years of driving before I get behind the wheel of a BMW .... and I am thinking, "why did it take me so long?"
... and then after another 4 years I can't believe that I have two of them !!
By "crank" I mean starter cranks so each of those "eee, eee, eee" noises.
Using Tapatalk
.... maybe your "long crank" is just normal for a M20 engine, but if you think it takes longer to start than the next M20, the issue is likely air intake leaks.
.... my chevy truck Vortec engine fires up instantly when I turn the key, but my M20 always takes a few seconds of cranking to fire up ... the BMW M20 engines have an ignition and fuel system that is different from north american and japanese cars so maybe you are comparing your long crank to the wrong reference,
Do you guys know how long a few seconds is when you're cranking your engine?
From cold starts it takes about 3 seconds for the engine to fire up, about a second when warm.
1997 328i/4/5 - Cosmosschwarz Metallic on Dove Grey - Auto/Manual Swap - M3 Bilstein Sport/H&R Sports (95 M3 mounts) - Offset M3 LCAB - 20mm M3 rear sway bar - X-Brace - AA Tuning Strut Tower Bar - Rogue Engineering RSM - Dinan Cat-Back - 3.38 LSD - E46 330 front/328 rear brakes - SS Brake Lines - E36 fitment Style 42's (staggered) - M3 Front Bumper - M3 side moldings - M3 Rear Diffuser - DJ Auto Headlights (6k HIDS) - Frenched Fogs - OEM Clear Tails - E65 Rearview Mirror (Homelink controls + Autodim) - Alpine Type S Cabin Speakers (6x9 Retrofit) - 8" JVC woofer - Black Kidneys - Red Needles/Chrome Gauge Rings - OEM Alarm - Full Interior/Trunk LED Lighting - Mishimoto Full-Aluminum Radiator - More to Come!
Thanks I'll check the ground strap and the intake leaks when I have the chance. Does anyone know the best way to hook the smoke tester up?
Using Tapatalk
