Checked the fuel pressure and coils today. Fuel pressure follows boost perfectly and changes when unplugged. Coils all came in at .7ohms.
I'm lost. Any more suggestions?
Did u try swapping the spring to a lower boost setting?
If you have bavauto coils I bet that's ur issue
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
That's what I'm going to try next. I'll remove the extra spring and leave the old spring in there and see if it performs the same as it did prior to adding it.
Do it and report back
Is it detonating with the higher boost?
Sent from my GTX3582R
Not that I can hear. Its a violent sudden loss of power that I can't accelerate through as the turbo fluctuates sporadically and the afr goes completely lean to 11.3 and back. It doesn't feel like a misfire at all. Car runs perfect otherwise and spools beautifully right up until full boost.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Your turbo isn't surging at the higher boost, is it?
WOT
I've personally never had surge going into boost, but I would assume the boost pressure would spike up and down, thus the AFRs could go wacky as well.
Your running a 2.5l? How fast does it spool?
WOT
The car makes no "blow off" noise, just loses power suddenly. Then tied to make it back up and it cycles
Post a video if you can.
Sounds like you have a hardware issue that is not up to 18psi. Have you tested the lower spring yet?
OK. When does it happen at what boost level cuts off?
So you hit 17psi, the car looses power, your PSI goes to... zero? and you don't hear the blow off letting the pressure out? Sounds like you are collapsing a hose or similar to that, maybe a piping connector coming loose. Did you test you system for possible vacuum/boost leaks?
I tested it to 20psi and sprayed soap on the connectors yesterday and found no leaks, I'm crazy anal about clamps so every possible connection is worm clamped. The boost only drops 5-10 psi ( hard to tell as the gauges go a little crazy) when it happens there is no noise of pressure loss.
Can you have something collapse post compressor though?
Your car doesn't have an over boost feature, does it?
I saw this guy on YouTube up his boost and it bucked like a bronco cause he forgot to up the over boost. It was funny.
WOT
The whole thing sounds really weird, you have no boost controller?
edit I just saw your response ^^
Yea man I got nothing sorry😳
What wastegate are you running?
Sounds like spark blow out to me.... but without any data trying to diag over the internet is hard to do.
get a video if you can.
