Hey guys,
So I saw a new trend that many people were telling me about and it is to use bug spray to clean headlights. I wanted to look into how it works and if it really works so I made a video all about it. People have videos on YouTube showing amazing initial results, but is it real and does it last?
Let me know what you think of the video and let me know what you have used to clean headlights (and did it work well)?
I use glass cleaner
Rain water does it for me.
Not so much a signature as a cry for help.
Hold on, saw this in a cartoon once...think I can pull it off.
A sponge works
PRICE CUT on ALL FABRICS
There's some confusion here: to clean them, I use ... glass cleaner. To get rid of the yellowing and oxidation, I use one of the many headlight restoration products followed by a UV protectant.
My E34 uses glass headlights, so it doesn't get damaged by UV rays and turn yellow
Lazy Saturday drive in my E34: https://www.youtube.com/watch?v=TnzvZgPnOos
Glass cleaner is not meant to clean plastic. I'm just putting that out there...
There are products to clean plastic...
I just buy new headlights. fuk cleaning them.
"Racing is life, anything that happens before or after is just waiting" -Steve McQueen
"Sex is safe & racing is dangerous" -Hans-Joachim Stuck
If you have slight hazing, use tire shine or similar product (the stuff that makes the tires look new and shiny). Spray some on a towel rub into the plastic, let it sit a few min then wipe up the excess. Works great on dull black trim too. Usually lasts a month or more depending on weather. Cheap solution till replacements can be bought.
Awesome I've wondered about this for some time now. I just use the buffing pads and buff it out.
I've "restored" the headlamps/taillamps on several of my cars, including the E39, its not that hard.
Sand to remove the oxidized coating, run it up to 1500-2000 grit, and spray with a GOOD 2k Clearcoat. The assemblies on the E39 are going on 5 years without any issues. But I also wash my car on a weekly basis, which I feel has alot to do with it.
EVERY BMW made after those era of cars are ALL plastic and that MOST the BMWs on the road are from the era of plastic lights, thus why I made my statement that almost all of them are plastic lenses.
I have a '72 bavaria and work on older BMWs regularly so I know they have glass lenses, but my statement was based on quantity, and there are many more plastic-lens BMWs out there now then there are glass. By a large margin
Something oily (like, possibly, bug spray or tire shine, but beware of anything with a solvent in it) can potentially fill the scratches in a hazy headlight and make it look shiny again... until the oily coating washes off and you're back to where you started from. If you've ever been to a gem show, you may see the same trick where a rock seller has a little tray of water and dunks a grayish rock into it only to have the rock turn bright colors until it dries. This is to show what the rock would look like if you polished it - again, using abrasives for a permanent measure.
Matt Cramer
1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
I've heard that clear coat spray paint works on faded plastic lenses. Clean them off good first to get rid of any dirt, then spray with light coats of clear coat spray paint. Allow to dry.
You will want to either remove the light from the car, or mask the area off real well to keep over spray from getting on the car. I've never tried it personally, but have seen it on a buddies car. It looked to me like it worked pretty good.
There's a video illustrating it makes the plastic lense look better for about 2 days.. It melts the plastic.. Take the time and do it right with sandpaper and buffing compound.. Or replace it
2006 X5 L83 5.3 6l80 swapped in progress
1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff
2007 ZX-10r - sold
1987 R-10 SWB L83 5.3L 6L80e swapped
One of the best plastic cleaner/polish/protectants is used in the aero industry, and it's called Plexus. amazing stuff.
