I have a slow leak from the ps hose on my 2005 X5 that I just got. It drops just a few drops per day and the plate on the underside is all wet. My mech says it is no big problem right now.
Do I risk damage to other components from a slow ps leak? Suspension components for example.
Thank you
Oil dripping straight to the ground is no big issue, just messy BUT it doesn't work that way. Depending on where the leak emanates from it could be fouling your alternator which is costly. Oil on rubber is bad, like belts and hoses. Oil saturated motor mounts always fail and oil blown back into suspension bushings will eventually soften them up to chewing gum.
Before ignoring your leak check where it is and where that oil is going.
[QUOTE=ross1;27932280]Oil dripping straight to the ground is no big issue, just messy BUT it doesn't work that way. Depending on where the leak emanates from it could be fouling your alternator which is costly. Oil on rubber is bad, like belts and hoses. Oil saturated motor mounts always fail and oil blown back into suspension bushings will eventually soften them up to chewing gum.
Before ignoring your leak check where it is and where that oil is going.[/QUOTE
Thank you, I appreciate your advice.
