So far on my quest to repair my dash lights, (instrument back lights), I have established a few things.
1. New bulbs
2. New fuses
3. My panel lights DO operate properly
4. Not sure if this is a factor but when I pull my headlight switch my passenger side tail and passenger lower front light are out.
My guess is that it's my dimmer/headlight switch. Anyone encounter this same issue or similar?
Any help is super appreciated!
Thanks guys.
***Update***
Just took apart the light switch and cleaned all connections and reset the springs that come in contact with the circuit board. I put it all back together and started her up, and STILL no results. Now I've narrowed it down to a ground wire..
So here's the stupid question of the day, where is the passenger tail light ground wire?
Once more with an update.
Located the ground location (G300)
I cleaned/sanded it and then also took care of ground 104 (near the driver fender)
And STILL no results, yet this time BOTH tail lights, BOTH front marker lights, and dash lights are out.
Not sure what else to mend here.
Any help is GREATLY appreciated,
cheers
