__________________________
1) Genuine BMW Bosch Alternator $45 shipped
80 Amp, Made in England
Part: 0-120-485-048
BMW Part: 12 31 1 730 580
Fits E36 323/325/328 and E34 525s and probably a few others.
The alternator works fine and spins easily and true with no ball bearing play. It doesn't spin completely silently by hand but it's been sitting for a few years and most likely will go away after being put into use again. (or won't be noticeable)
2) Bosch Starter $35 shipped
Bosch Part: 1-005-821-506
Used starter for E36 323/325/328 models. It may be compatible with E30 3 series and other models.
As you can see the starter will not be winning any beauty contests.
3) Water Pump for E36/E46 $30 shipped
Original BMW.. absolutely no play in the bearing, but already bought a new one so replaced it anyway.
4) Mass Air Flow Sensor / MAP $50 shipped
BMW Part #: 13 62 1 703 275
5) New USB OBDII DCAN cables $20 shipped
6) New E36 318 Engine Mount $35 shipped
One (1) New E36 318 Corteco Engine Mount $40
11 81 1 141 377 (also: 11 81 1 137 775)
Stock photo:
I'll take the cables. Pm sent.
Do you still want the cables?
Bump.
Private message sent
Haven't heard back. So everything is still available.
starter and alternator are sold, everything else is still available
Forgot that I still have these. Bump.
