Results 1 to 13 of 13
Thread: 1.2 or 1.4 bar overflow cap for e39? stock
    Mar 2014
    Texas
    97 528, 95 525, 03 525
    Hello. Was wondering if there is a newer model stock cap say from a standard bmw with a lower bar rating than stock e39? Will any of the factory recovery tank caps with a1.2 or 1.4 bar rating fit the e39?
    Why do you want to do this?
    Why not just bleed the system properly and use the correct components? I'm never sure why garage mechanics think they can out-engineer the thousands of well-paid BMW engineers who designed these cars.
    The overflow cap should NOT set the pressure for the system anyways!
    PRICE CUT on ALL FABRICS
    Michigan
    2005 325Xi
    The expansion tank cap is designed as the weak link in the system, so when something else fails and the engine overheats, it's the first thing to go so that the coolant is vented in a relatively predictable manner instead of hoses blowing off randomly. There shouldn't be a need to vent the cooling system normally.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Mar 2014
    Texas
    All due respect anyone know the answer to my question.
    I'm an doing this because I have an external head gasket leak and I want to reduce pressure on it. I did a block test it is purely an external leak.
    May 2005
    san francisco
    E36 M3 , E39 540is
    after market by motorad part #T43 is 20lb instead of 30lbs
    its basically a cap for a e34 525i , i have one sitting around, but im not sure if it will tread on to the tank, most local auto parts stores have them, i ran into your problem as well a while back, but i ended up not driving the car till i fixed the HG, good luck man
    http://www.motoradusa.com/motorad_ca...l+L+%282494%29
    "Racing is life, anything that happens before or after is just waiting" -Steve McQueen
    "Sex is safe & racing is dangerous" -Hans-Joachim Stuck
    Mar 2014
    Texas
    Quote Originally Posted by rob22sf View Post
    Thanks. I really appreciate it. I'll look into this soon.
    May 2005
    san francisco
    E36 M3 , E39 540is
    Quote Originally Posted by Sleepyhead97 View Post
    no prob bud, just be careful when you screw it on, I'm not 100% sure, I never got around to trying it, but from what I can remember it looked very close. let us know how it works out
    Jul 2012
    mitten
    525it,02 525it,73 2002
    German auto solutions https://www.germanautosolutions.com/...12_bar_cap.php
    they make some nice stuff
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I run the earlier 140kpa cap instead of the 180ka cap. Did not know there was a 120kpa cap. You can run zero kpa. Just keep the cap a little loose.
    Kentucky
    '03 Z4, '06 Forester
    WHAT?
    Open system will boil the water instantly, overheat and spit it all out ... good way to ruin your motor.
    Jun 2005
    New England
    The OP wants to run lower pressure. 0 is possible. We do not know why he wants to run less pressure. Evans coolant, which I run, is fine at 0 pressure and boils at 370F.
    May 2005
    san francisco
    E36 M3 , E39 540is
    his HG is blown, that's why he wants to run a lower PSI, KPA etc...
    Mar 2014
    Texas
    Went to the parts store and picked up a radiator cap for a 1988 325i. Marked at 140kpa. It is the exact same dimensions as my 200kpa. I installed the cap in the parking lot, drove off seems to be working fine. The pressure of the hoses dramatically decreased from the 200kpa cap.
