Results 1 to 6 of 6
Thread: Engine name where? - M50B25
    Jun 2014
    Denmark
    1988 BMW 527i Sedan
    Hello Bimmerforums,
    So tomorrow im going to check out this E30 with a M50B25 in it, however I am wondering, where exactly can I see the name of the engine?
    So I can confirm it is actually a M50B25 and not just something similiar.
    Thanks in advance!
    Nov 2005
    SAN ANTONIO,TX
    E36,Datsun510.T-Tundra
    ...When you get a blackeye from trying to change the shift knob.
    Jun 2014
    Denmark
    1988 BMW 527i Sedan
    Seems like thats gonna be a challenged on that engine looking at it, on the spot.
    So now I know wheres it located, however are there anything I should look for, to make sure its a M50B25? (As I probably wont be able to see the id number)
    Also the numbers I see on other engines, I cant find those in that .Pdf you posted?
    Nov 2005
    SAN ANTONIO,TX
    Look at the obvious
    M50 Manifold, Vanos Selenoid, oil cap location
    But to answer your question correctly, only way to know is to look at the block marking near the driver's side engine mount bracket.
    For example there will be engine serial number and right under it will be engine type coding.
    25 s 6 1 (2.5L M50)
    30 s 6 1 (3.0L S50)
    28 s 6 2 (2.8L M52)
    25 s 6 2 (2.5L M52)
    32 s 6 2 (3.2L S52)
    30 s 6 3 (3.0L M54)
    or
    Pull the coil and the plug and measure the stroke using a wooden dowel.
    s52 is 89.5mm or just a tick over 3.5in. s50 is 86mm 3.4in m50/2 will be 84mm or less.
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    You can tell easy if it m50/s50, m52/s52 but that 's all that matters you don't have to cheack anything else, it has to be at least 2.5 doubt it's 2.3. Anything else is a bonus.
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    Quote Originally Posted by CMG View Post
    Since OP is euro, it could be an M50B20 as well..
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
