Ive heard that the 4 prong plugs (like alot of the factory BMW plugs) take a crap load of energy and will exploit a weak ignition component very quick. I have no facts, just something ive read
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
I have always wondered why people here don't talk about ignition upgrades. Are factory coils really strong enough for the turbo systems common today (4094/6266)?
Honestly curious.
That brisk advertisement is comedy.
Normal high performance race plugs that are used in professional race cars.
Our ultra monster plugs. raawrrr!!! Open the gates of hell!
I love me some iced tea
Rob #43 ITS/ITR/STU, BMW 325I, STU LAP RECORD
SUMMIT POINT WV 1:24:229 S.C.C.A.
(DynoDynamics https:vimeo.com/8486878 Dyno Video)
"Chance Favors The Prepared Mind"
Need Help With Your Nitrous Ambitions ?.....PM ME
Most people (including myself at the beginning) tend to believe old ass coils and boots are going to get you by, so you're there gapping your plugs down to avoid misfires.
But in reality anything but new coils probably won't fare too well or very long.
Factory coils seem to be decently strong and have good spark energy output, but that's probably no longer the case with people running old/high mile coils and boots.
Most of the time a solid ignition system should support at least 0.030" gap under boost IMO
Not running enough power to have problems.
I run NGK 4554 at .018" with no problems up to 30psi.
There are ignition amplifiers available for anyone to incorporate if they really are looking for big torque and don't want to change plugs as often. For a 500+ ft-lb street car though on pump gas, reading the plugs every few thousand miles to ensure the engine is running healthy is cheap insurance. I check them long before they start misfiring for my own sanity and the overall health of the engine.
Mike
IG: @mikevanshellenbeck
After finally being fed up not getting anywhere with old/used stock OBD2 coils and boots, I've switched to VW/Audi DI coils (long ones) which I got for free. They're cheap and work really well as they have a very powerful spark output. Generally being able to run 0.031 or larger gap up to 30 psi isn't an issue with them.
Of course the issue with them is they're active coils and aren't able to be used with the stock ECU which is only able to drive a dumb/high power coil pack (3 wire).
I knew a dude who was running plasma ignition on his Audi build. Very cool stuff. Got a decent power boost out of it, very clearly proven on the dyno.
http://spdispark.com/
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
BOOST-A SPARK
I have one of these sitting new in a box, never got around to installing it. I of course believe it will work.
One thing I really like is the fact that you can use it with a WOT switch, this way you're only taxing the stock coils
for a short while. This should provide a longer coil life.
http://www.kennebell.net/KBWebsite/A...oostaspark.htm
http://www.mazdaspeedforums.org/foru...t-spark-63536/
Good luck,
Rob43
Carwiz008, thanks for sharing the laser plugs. Never seen that before.
A really strong and long single spark event is much better than a bunch of weaker ones like CDI.
Well first of all nobody said it was the same as laser spark and nobody's tryin to rain on your laser parade or anything so no need to be defensive - just throwin some info out there. But second of all, I'm not sure it's as completely different as you suggest. Doesn't the laser spark create some plasma state in the combustion chamber as well? The method of plasma initiation is different for sure but both derive some of their benefit from creating plasma in the combust chamber.
In re: their system - yeah I think by initiating plasma in the combustion chamber, the effect and mode of action here is nothing like a multiple conventional spark. The pulses are there to maintain the plasma state in the combustion chamber which is what they claim supports efficient flame fronts and makes combustion more efficient. All I can say is I've seen a car running it, know a guy with 2 cars in his families running it, and it was entirely effective and seemingly reliable. No relation / interest on my part aside from technical interest - seems like cool stuff.
The bigger argument against it if you want to be hater is the cost - its bux for sure. But then again a laser spark system is gonna probably be a few mortgage payments more expensive than this...
The plasma setup is nothing like CDI multiple spark if you look at their tech info - CDI doesn't come anywhere near to creating plasma in the chamber. They have one big spark then support plasma with reduced pulses afterwards. So it's not an either/or its an 'and' situation... Again not trying to be a fanboi for that setup just clarifying what it is.
2003 M3CicM6 TiAg
Former:
Thanks for clarifying!
So how powerful of a laser we talking here, can i tear apart some old dvd drives and make some laser coils?
1989 535i - sold
1999 M3 Tiag/Dove - sold
2003 M3CicM6 TiAg
Former:
