Hello all!
It's been a while since I've had the privilege to pay over here as I've been working out the links in my s54 e36 build. You guys always have the best answers so I figured if start here!
I'm running a gutted s54 powered e36 with Bilstein PSS coilovers with hyperco 500f 600r springs with turner blue bars full stiff front and full loose rear. Ground control camber plates up front and a set of grand am conti takeoffs from jpjp.
I have read the 'definitive suspension setup for e36 m3' thread that is madly popular, but I'm assuming things are different with the s54 and slicks.
I'm not sure what would be the ideal setup for my suspension. I really need your help and wisdom!
Ride height, camber, toe... The whole nine yards so I can dial this alignment and setup in. I'll be spending most of my time at road Atlanta Sebring, barber and various autox
I'm all ears guys!
Cheers!
Patrick
Xbrace as well : )
It really won't be any different. What will be different is the alignment from track to autocross. I run less toe in on the rear (almost 0) than I've read about from the track guys. With the intention of getting more rear rotation.
I haven't done a single track day with the car. For Autocross....
Front:
Camber: -3.5
Toe: total out-.2
Sway bar: 24mm attached to the LCA.
Rear:
Camber: -2.0
Toe: total toe in-.2
Away bar is stock 325i. Looking to go to an M3 stock bar.
A lot of drivers set rear camber about 1* from the front.
MCS somewhat recently came out with a 2-way non-remote damper set which starts at $3,400. http://store.bimmerworld.com/mcs-mot...set-p1964.aspx . 1-way starts at $2700
A great alternative to the full blow remote set up. I have had great luck with MCS customer service and been very happy with my selection.
Tristan- 97 M3 #154 STU
2012 SCCA SOLO STU National Champion
2012 SCCA SOLO Rookie of the Year
I don't know from first hand experience, but can repeat for you what I've read on the Internet (and heard today in a tech session given by Edge Motorworks, who work on and track or race many BMWs).
If your car is dialed in correctly for one type of tires then you get stickier tires, you probably want more negative camber and higher spring rates. Higher spring rates want stiffer rebound settings and you might want stiffer bump settings too, if the PSS dampers allow that. But the only way to see if you have the right amount of extra negative camber is drive it, see how it feels, and take tire temps or watch tire wear. Stiffer spring rates and more camber may mean you can soften the swaybars, but you need to drive it to figure out if the swaybars need changes.
Then if your spring rates go above what the dampers can you, you'll need them revalved, or get new dampers. If you add power (S54), you might enjoy wider tires to aid in acceleration out of corners and braking upon corner entry. Then if you still need more grip, look at aero
I just got a set of TRM coilovers for my E36 track car. It's certainly not an S54 beast like yours but it's track-only so I wanted stiff springs. I went with 900/1000 springs and apparently the TRMs are valved to handle up to 1200lb springs. I haven't installed them yet (i'm installing a rollbar, steering wheel and seats/harnesses now) but as soon as I get a dry weekend, i'll install them, get an alignment and tell you how they are. My friend level8drummer has the TRMs on his daily/track car with 1200lb springs and swears by them. They're also much less pricey than the other suspensions listed above.
I definitely will! We'd spoken a while back about your S54 conversion. I would have loved to do the same. Maybe I will down the line. We should definitely meet up at the track someday. We're running with PCA at Roebling Sept 20th. We went to Barber back on Memorial day with BMWCCA Heart of Dixie chapter.... That is one beautiful track! I still haven't been to Road Atlanta but I really wanna see your car out on the track!
I remember!
Heck yeah! I want to do Roebling and Barber soon! road Atlanta will be a staple for the rest of the year for me. I know for sure I'll be up there in November for the turkey trot through Mvp track time. Great event! It's going to be one heck of a change getting this thing out on track with all this power/suspension changes. 5 to 6/10s will be mandatory for the first couple runs!
I'd start with the front as low as you can get it without rubbing (under heavy load) and then set the rear 1/4" higher. Then do corner balancing with the sway links detached, your ride height will be all messed up after that of course, then set camber, caster and toe. Front -3.0, rear -1.8. Max caster. 1/8" toe out in front, 1/8" toe in for the rear. This is what I use for my s54 e36 with MCS 2 ways and it's the ticket. Rick
haha you and I both man and I have nowhere near the power you have! I did my first several track events on stock suspension and am now swapping on super stiff coil overs and have stripped another few hundred lbs from the car.. It will be a totally new beast, even with the puny M52. I'm going to get used to the new suspension with the M52 before swapping in an S52. I really would have loved to do an S54 like yours, but it just wasn't in the budget. I'm dying to see your swap in person though!
