Results 1 to 1 of 1
Thread: 750ia e38 broken gasket
    Jul 2014
    Toulouse, FRANCE
    1997 750I E38 ShadowLinE
    hi folks,
    i have a 1997 750ia with 196.000km on it, the engine has an overheating problem. i have the message that says ''check the cooling liquid'' since i have the car(4months) but the cooling liquid level was always good every time i checked it untill the overheat problem. so i ve driven the car for 2 months with the messege apearing randomly but without engine overheating.... but after the first time the overheating problem repeated itself for 2 months now... the mechanic said that there is a huge pressure inside the cooling system and it is a sign of a broken gasket etc. the engine runs and rides smoothly but im not sure whether to repair the gasket or change the engine with a younger one. because i m told that gasket problems repeats after a some time so i would like to have your ideas about this.
    (i also have a strange noise coming not from engine but from some where like the middle of the car. anyone have the same noise ? )
    here is the video: watch that little thiny noise after startup.
    https://www.youtube.com/watch?v=qvwS...ature=youtu.be
    thank you in advance
    Erek
