Are you looking for a nice CAN Clip?If you do,you must take a look at this wonderful product.It is the Newest Version:V139,and you can see its functions as follows:
1. See all the information relating to the vehicle
2. Computer test
3. Automatic test of all computers
4. Reprogramming
5. Airbag test
6. Scan tool (OBD tests)
7. Base Doc (access to Technical Notes)
8. Physical measurements
9. Antipollution
10. Multimeter
And then i will tell you more details of it,are you interested in it??
Renault Clip V139 Specifications
1. Dimension: 32CM*19CM*9CM
2. Languages: English,German,Brazil,Denish,Spanish,Finnish,Frenc h,Italian,Norwegian,Dutch,Portuguese,Romania,Swedi sh.
(The language of V139 version is just the same as V130 version)
It's very simple to diagnose a vehicle using Renault CAN Clip Diagnostic Interface: just select the vehicle make, enter the V.I.N. and press ENTER.
Renault CAN Clip Registration steps
1. After finish Installation, DO NOT run your CLIP!!!
2. Copy the RSRwin.ext to C:\CLIP_X91\Lib\Application\
3. Then run your CLIP, choose "Register me now" and in the next Windows, please select "NO"!
4. Use this Key for Registration:
333DEF-111DEF-111DEF-222DEF-221DEF-000DEF
So,what a wonderful Renault CAN Clip,if you really like it,you can just buy one,it must be a great choice!!http://www.obd2space.com/renault-can...interface.html
