Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 119
Thread: Spa T4 manifold...Turbo fitment????
  1. #76
    Sep 2008
    Toronto, ON
    6465 328ti
    Quote Originally Posted by highboostingm3 View Post
    Great info. That ends that debate. They need to shrink down their damn housings if they want to sell more units. Fitment is key, especially under the bonnet of today's cars with all the extra electronics and smog crap going on in there. It's just getting tighter and tighter...not the other way around.
    Yup! I saw on full race there was one of their newer turbos that had a "normal" sized T04S compressor housing. They should continue the trend to all their models!
  2. #77
    Nov 2013
    VA
    E36
    [QUOTE=RandomHero27;27785431]was that the mani that was on ebay from "powder coat" something or other? i had been eyeballing it for a few weeks.
    Yea it was. Unfortunately it still has not been shipped and the ebay seller won't answer my messages :/....I'm getting impatient.
  3. #78
    Chicago,IL
    330ci E46/E36 hybrid
    Yeah it sucks I had to find out the hard way lol.
    I completely agree. BW really does need to downsize their housings. They are cheap and make great power, but the packaging needs work. An equivalent power making Precision is much smaller and lighter. Those turbos are better suited for bigger engine bays I guess. BMW need not apply haha.
  4. #79
    Montreal, QC Canada
    328is GT35R
    Damn you guys got me worried with all this cutring gasket and copper spacer talk.. have a set sitting in my room waiting to go on my m52.. when i do the head job ( hopefully within the next two weeks) ill take some pics too. In my messages to ces i was clear it was going on an m52 and they made it sound like the gasket and spacer combo was one specifically for the m52
  5. #80
    Nov 2013
    VA
    E36
    Quote Originally Posted by daze450 View Post
    Measure the bore of the cutring and spacer and let me know what you get. I spoke to John at ces and they have a shipment for m52 spacers coming at the end of the month...said he'd hold one for me. I finally got the t4 manifold as well. Good quality but I'm a perfectionist so I took a dremel to it to smoothen the rough edges on the inside...I'll post pics soon.
  6. #81
    Montreal, QC Canada
    328is GT35R
    Bore on the ring is 84.3 and the spacer is 86
  7. #82
    Mar 2003
    Hell Hole, NC
    325i
    Please get the measurement on the OD and ID of the cut ring please.
    Fast lookin' but slow movin'
    237 rwhp N/A power
  8. #83
    Montreal, QC Canada
    328is GT35R
    Id 84.5 od 91
  9. #84
    Mar 2003
    Hell Hole, NC
    325i
    Thank you!
    237 rwhp N/A power
  10. #85
    Nov 2013
    VA
    E36
    M52 bore is 84mm. Cutring is fine but the spacer is more for the s52. I'll let u know what they send me
  11. #86
    Feb 2010
    Granada Hills, CA
    1998 M3
    sooo..who's going to try a borg warner with the Spa bottom mount?
  12. #87
    Jan 2014
    San Antonio
    98 328is
    Quote Originally Posted by 1980corvette View Post
    i was thinking of doing a spa with a bw airwerks s256, the consensus is that the s300 series is a tight fit and requires a bit of messaging, the s200 should be fine. but it might be awhile, turbo thoughts turned into thoughts of building a workshop in my backyard instead.
  13. #88
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by RandomHero27 View Post
    F the workshop. SPA + S200 BW.
    Get it done, dyno and post. There are guys out there that need a reliable budget system.
    If my garrett quit on me, id be looking at either one of these or a JB 626X.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  14. #89
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Quote Originally Posted by mazdero View Post
    You guys just have tiny spaces on the exhaust side - not BWs fault. The EFR is an "all-in-one" package with an IWG, which leads to a long housing. They are barely longer than a competing Garrett or Precision Chinese knock-off if you go with an EWG housing, and that all comes from a more robust bearing package.
    I doubt the Precisions are that much lighter with their thicker housings(BW SS housings are thinner due to their higher high temp strength), and considering that many of BW's EFR turbos now come with aluminum CHRAs, which save over 2 lbs.
    The EFR series definitely has some downsides, but the compromises were made for good reasons. I've always liked their technical solutions, I just ragged on them when you had to be on a wait list for 1.5 years to get a turbo. Now that they are shipping very readily, and they've improved the line quite a few times (Garrett moves like a sloth for technical advancement) - what's not to like?
    If you want a tighter packaged BW, get an Airwerks turbo - they're dirt cheap for what they are, and not made in China IIRC.
  15. #90
    Nov 2013
    VA
    E36
    I just received my spa t4 manifold. Very good quality but I took a dremel on the inside edges to smooth it out a bit. I'll be using n54 studs and copper nuts to mount it to the block. Below are some pictures
    I also just purchased the cutring gasket, spacer, and studs. I'll take a set of calipers to it and see if its 84-85mm once they come in.
    Does anyone know the thread pattern for the 4 holes where the turbo goes? It looks like M10X1.50x25mm but just wanted to make sure. I'm going to go with the stage 8 turbo bolts part #3904.
  16. #91
    Montreal, QC Canada
    328is GT35R
    I spoke to CES and the copper spacers for the M52 are in apparently, gonna send mine back to get one.
  17. #92
    Nov 2013
    VA
    E36
    I already discussed this...ordered mine and it will be in later today...I'll post pics
  18. #93
    Feb 2010
    Granada Hills, CA
    1998 M3
    s200's are all T3 huh..
    my spa is T4 and although a 6266 is an easy and proven option...i want to pull the trigger on a s362 and see what i can do with fitment but don't want to be stuck with it after if it doesn't work out
    maybe i can find someone who'd be interested or i can always try to sell it on the evo or supra forums
  19. #94
    Aug 2003
    San Diego,CA,USA
    1997 Turbo M3 Coupe
    DO IT...DO IT.
    You can always sell it afterward.
    Post many pics with many angles showing fitment.
    In the name of the highest frequency called LOVE for all of BFCFI.
    Where have I been? Astral projecting.
    Quote Originally Posted by jszy25 View Post
    Get drunk with Mike Radowski they said, it'll be fun they said...A broken toe, the worst hangover known to man, and bite marks in my arm said otherwise
  20. #95
    Feb 2010
    Granada Hills, CA
    1998 M3
    DO IT...DO IT.
    lol thanks for the encouragement
    but it won't be for a while, i have the moneys almost ready, but am going to try to time it right so i can only pay half a year of insurance, and finish the entire car within the second half of the year..
  21. #96
    Jan 2014
    San Antonio
    98 328is
    the s2/300 series on smeding diesel say they are T4
    http://www.smedingdiesel.com/category-s/200.htm
  22. #97
    Chicago,IL
    Quote Originally Posted by bmw328m52 View Post
    thats high for those studs. I got them for 176 shipped off amazon. Don't forget to port and shape the wastegate hole.
  23. #98
    Oct 2012
    NYC
    93 e36 sedan
    I wish you would because thats the same turbo I want on my spa. I've read its physically smaller than the s366 by a large margin... I'd go with the 90* elbow too.
  24. #99
    Dec 2008
    Earth
    none
    The s364's(billet) the S366's(billet) along with the s368(cast) are all the same sizes, at least what I have at my shop currently.
  25. #100
    Feb 2010
    Granada Hills, CA
    1998 M3
    found this image of the 6262 v the s366
