So I just got home from work and I noticed that my car was leaking fluid. I touched it on the ground and it felt kind of oily in my hands. The car hasn't been running or idling rough in my opinion. It is also 80F outside today so Im not sure if that could have anything to do with it. Is this an issue that I need to take care of immediatly? Or will it sort itself out/ get to it when I can. Here are some pictures of where it is to help identify the locations and what it is.
http://i.imgur.com/bPqgxfR.jpg
http://i.imgur.com/TzF0lqM.jpg
http://i.imgur.com/gicsziu.jpg
All that fluid came from your car? That's too much!
I would jack it up for a better look. It looks clear so it may not be the transmission fluid, is your car manual or auto?
Can you also kindly post a pic of the leak puddle without the car?
I would NOT drive it until you check it out or visit a doctor...
Well, I can pretty much guarantee you that it's not going to "sort itself out". Leaking components seldom heal themselves.
From those pictures the fluid looks yellow-greenish to me -- what does that match up to, when looking at your car's fluids? Is your coolant/antifreeze greenish (or is it the BMW blue stuff)?
You really ought to not drive the car until you have the issue identified and, preferably, fixed. Unless you like getting stranded, and spending more money when a cascade of failures follows the original part failure.
Looks like washer fluid lol
is that possible? Cause honestly that was one of my first thoughts.... my sprayers don't currently work so maybe they are leaking? also I am having a difficult time finding the transmission fluid area... really really brand new to cars and especially this one but bought it to learn as much as I can. Also does anyone know here to purchase a new one of these covers? Mine seems to have broken upon me screwing it back on (silly 20 year old plastic) http://i.imgur.com/KwUyKNl.jpg it is "secure" but where can I get a new one?
Here is the spill under the car. Currently blocked in so I can not move it. http://i.imgur.com/hNC7snt.jpg http://i.imgur.com/NWHn7Ro.jpg
On seeing the pics, I don't think it is washer fluid. There is way too much of it and the washer bottle is located above the dry area.
It looks like it may have dropped onto the bell housing on the driver's side and run down. Is it possible something else was disturbed or broke when you were working on the water valves? No disrespect - as you say, it is 20 year old plastic. Maybe use get a mirror on a stick if you cant see?
I was never working on the water valves before this happened which is kind of the problem.... and no disrespect taken even if I did this haha. I guess I will be getting one of those soon then or just bite the bullet and get jacks. I am also in need of an oil change could these two be related?
IT is coolant!! i just checked the coolant container (can't think of the right term) but it was the same color and texture.
Yeah that looks just like my coolant puddle I have in my driveway (fan nicked my upper rad hose)
I know this is just the worst week for this to happen.
OK so I added water to my expansion tank and drove around my neighborhood and when I parked and lifted the hood I immediately found the leak. It is a hose!!! I found the part on realOEM. None of my local auto parts stores have it so I guess im ordering it online. Has anyone had any experience with Rein automotive or URO parts? I dont feel its necessary to go full BMW OEM and spend $$$ also once it is on do I add coolant to the expansion tank?
