Results 1 to 4 of 4
Thread: E46 320d engine vibrate when start, please help.
    Apr 2014
    Czech rep
    Bmw e46 320d
    Hi I have Bmw 320d 110kw and when I start and turn off engine engine is vibrating shaking knocking. I changed engine mounts new Clutch and flywheel injections replaced and its always the same nothing change. Can anyone tell me where is problem please? Very thanks!!!
    Video.....
    https://www.youtube.com/watch?v=46tS...ature=youtu.be
    Most of us are US based and thus petrol-centric. I cant offer much help, but boy that engine looks different from their petrol engines
    PRICE CUT on ALL FABRICS
    Zionsville, IN
    93 740i, 84 533i
    If it only happens when cold and you have already checked / changed injectors, look toward the glow plugs. A bad glow plug will keep that cylinder from firing and will cause an obvious rough idle
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    Jun 2008
    New Zealand
    545i, 740i, 320i
    My 330d always idled rougher in cold weather from new, so if it's only a mild vibration that goes away when the engine warms up I wouldn't worry about it. If it is quite noticeable then it probably is glowplug related. Try leaving the ignition on for longer before you first turnover the engine to give the glowplugs more time to heat up and see if that makes a difference.
