I need a turbo kit for my 325is that has good downpipe and feed and return lines any suggestions if so can I get some links to where I can purchase the kit thnx
Michael McCoy TRM
Sweet does anyone know where I can find a full downpipe to fit these ebay t04e t urbos
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Thers a place called DIY ....
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
To be honest, a downpipe and return/ feed line are on the lesser end of your worries. Spend some time in the FI section researchin will be your best options. Also check the FI classifieds for a good kit that might pop up.
Can anyone give me links to these pages on downpipes I already have my fuel system with 60 lb injectors and 355 fuel pump
Which turbo and which manifold are you buying the downpipe for?
What is your budget? If your budget is south of $3,000 then there is a great thread regarding an ebay kit which has worked well (he had to purchase stock DME tuning and MAF with harness from RK Tuning though).
If your budget is up to $6,000 for a kit then TRM has had great success with the 325 on the track with their kit. Another good kit is Technica where the two kits are pretty similar but Technica might get you more power if you are looking to do a head spacer/stud setup for more boost.
How did we get from "Help, which turbo kit is the best" to Ebay?
Or am I missing something?
lol
