Sup yall. 1995 M3: My steering wont naturally return to center after driving in the rain. I can rotate the wheel 80 degrees going 50, let go of it, and the car still turns. After a few days of dry weather it feels normal again. Yes, I have a small power steering leak somewhere. And yes, it still feels like I have power steering when going slow/parked. I cant find anything about this on the forums. Anyone have this same problem? Is water getting into my steering rack?
stay wrenchin
Any noises while turning from the wheel itself? There is a known issues with the upper column bearing, they wear out and start to become stiff. I had this issue with a 97 M3, it was super stiff on turning the wheel. After replacing that bearing, it was easier, but now it doesn't like to return to center on its own.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
No noises at all
Update: Apparently a friend had a similar issue and the fix was to lube up the u-joint on the steering input shaft. Im going to try this when I have the time. I will give another update on whether it works or not.
stay wrenchin
Cool, I will try the same to see if that helps.
Darin
Current:
Past:
M-Flight Member
Finally drove in some rain. Spraying the chain lube on the u joint worked for me.
stay wrenchin
Thanks for the update, still haven't tried it out yet, but it is getting looser as the weather warms up.
Darin
Current:
Past:
M-Flight Member
