Results 1 to 7 of 7
Thread: Electrical oil pressure gauge for 1500psi (100 bar), where to buy???
    Jun 2006
    croatia
    BMW m3 e36 1994
    Hello
    I cant find electrical oil pressure gauge which can measure oil pressure up to 1500 psi or 100 bar. Want electrical because dont want to have hot oil under this pressure in the cabin
    I want to monitor Vanos oil pressure in euro s50b30.
    Here is gauge but I want to have smaller gauge in cabin.
    thanks
    http://www.youtube.com/watch?v=Ocrvaw3d4UM Dont drive over limited speed!!! Drive safely......
    Oct 2008
    Media, Pennsylvania,
    1991 325i
    and why does it have to measure up to 1500psi?
    1991 BMW 325i(Current Daily) (S52)
    I have carburetors, and I'm not afraid to use them!
    There are always other fish (engines) in the sea (Craigslist)
    Life is about enjoying the engine you are sitting behind.
    Jul 2010
    KC, Mo
    04 M3, 02 E39, 01 46 M3T
    +1. I believe that the VANOS operates at engine oil pressure levels ---- unless there is a secret oil pump somewhere that nobody has ever seen!!!!
    Charleston, SC
    '15 I01Rex , '11F25
    The s85 has its own high pressure Vanos pump, in fact if during any kind of engine repair if you rotate the engine backwards it will supposedly destroy the pump.
    Jun 2006
    croatia
    BMW m3 e36 1994
    vanos on euro engine have its own high-pressure oil pump build into vanos on front of engine head. this pump produce 1500 psi oil pressure which I want to monitor.
    Vanos bible : http://www.scribd.com/doc/72923064/BMW-szelepvezerles
    NW suburban Chicago
    hiss by my window
    You are looking for high pressure transducer
    Jun 2006
    croatia
    BMW m3 e36 1994
    Quote Originally Posted by ross1 View Post
    what is this transducer?
    maybe is this what i need but cant find any info for what is it?
    http://www.summitracing.com/int/part...2240/overview/
