So, I have been wanting and old e36 project for a while, and I recently picked up a bone stock 1994 BMW 325is with 197k miles on it for pretty cheap. Runs strong and shifts well, just needs some basic maintenance and exterior clean up, previous owner took pretty good care of it. I will be documenting the progression here and on youtube as well. On to the plans!
Since this will be a dual purpose autox/HPDE car of sorts on somewhat of a budget, I don't expect it to be super competitive in STX. Mostly going for fun factor and something I can take to autox as well as the track with a setup that will be suitable for both. It will be built with STX rules in mind however, as I don't want to class myself out of that just yet. The car is not a DD, I have my e46 and another car for that, but I will probably keep it street legal until I get a tow rig.
Maintenance plan:
- Replace leaking valve cover gasket and seal washers Done
- Replace leaking differential seals and diff fluid Done, new LSD
- Fix driver window (driver side works intermittently) Done
- Remove rust from drip ledge and paint Done
- Touch up paint chips Done
- Detail the car Done
Upgrade plan:
- Wheels: 17x8.5" TR Motorsport wheels with Dunlop ZII 245/40/R17 tires
- Option 2 if $$ available: 17x9" D-Force LTW5's with Dunlop ZII 255/40/R17 tires (I know these are optimal but are $450+ more than the 17x8.5"'s)
- Purchased: Apex Arc 8 in 17x9" et42, Silver
- Purchased: Hankook RS3v2 255/40/r17 tires
- Coilovers: Thinking KW V2 or Bilstein PSS9 - other opinions in that price range? AST/TC Kline are a bit over what I want to spend.
- Purchased: TCKline double adjustable suspension with camber plates!
- Camber plates: TCK
- Sway bar: H&R or Turner front bar, not sure what the common thickness is...27-28mm?
- Purchased: Eibach 28mm front bar.
- Brakes: Ferodo DS2500, new stock rotors, maybe better rotors if $$ allows
- Differential: Used stock LSD...will an e36 M3 LSD fit this car?
- Purchased: LSD 3.15 fd diff from 325i with 80k miles on it
- Purchased: New diff clutch discs and carrier bolts
- Seats: Corbeau seems to be the cheapest, but a fixed back set of seats of some brand
- Engine:
- Lightweight exhaust, high flow cat, not sure on brands yet
- aFe intake - scratched, stock is good enough.
- Header, no idea what brand yet
- Tuning, TMS seems to be the way to go?
- Purchased: TMS chip used
- Other: Lightweight battery
Couple pictures and my first video of the project!
1994 BMW 325is - Project 325 HPDE/TT | 2013 Scion FRS - Project FRS STX | 2017 Subaru BRZ - Project BRZ STX
For the wheels, I would either save up for the 17x9 or try to find something used instead of getting 8.5s
How about the GC track setup if TC Kline is over your budget?
For the LSD, you can rebuild a stock one to a 3 clutch one with new ramps for about $600.
The H&R bar is 28mm.
The Dunlop ZIIs are discontinued, so if you want them, order soon.
Priority order should be:
Tire compound
Wheel width
Springs (including sways)
Save the money from camber plates. 96+ M3 strut mounts can give the camber.
Your stock front sway bar with strut mounting might be slightly too much front bar. Decide coil spring rates first. Most people are running a lot of front coil rate and comparatively little rear coil rate and thus can't effectively use much front sway. But that is not the only solution.
All the stock-style rear bars do nearly nothing. Useful for fine tuning.
Cheap semi-metallic pads work great for autocrossing.
I figured as much on the M3 diff...just curious as I saw one on craigslist locally. I will keep an eye out for the 325is LSD from a manual car.
Yea I think I am going to save up for the 17x9" wheels. While I want to be budget minded, I also hate skimping on things when I could have better, hah.
Is this the GC setup you are talking about?
http://www.ground-control-store.com/.../II=828/CA=172
If so, that does look pretty good, especially since it includes camber plates and you can select the desired spring rates. Hmm, thanks for that tip!
ZII's are being discontinued already? I just bought a set when they came out last year for my Miata
I will be using a ~200tw tire of some sort. ZII's are my favorite for dual purpose, I like RS3's as well and autocrossed an RX-8 with Rivals, not sure I want the Rivals for the track though.
Spring rates and the bar I am still not sure, so will do some researching on that and open to suggestions.
For the pads, I just wanted to try something different than what I had on my Miata (Hawk HP/HP+). I suppose I could save some $$ with cheaper pads.
Thanks!
Unless he is planning to trophy at nationals, I wouldn't care. The '95 M3 diff is the same ratio (3.15) and the only difference is the ring gear bolts are M14 vs M12. Whichever you can find first is what I'd go with.
ZIIs are being replaced by ZII star specs, but NA won't be getting them until later this year. You'll probably see the popular sizes (255/40/17 and 245/40/17) go out of stock before they get the new ones.
Skip the intake for sure (afe is expensive AND the fitment sucks, stock airbox is GOOD), and look for a used chip if you want one. The marginal gains from these should not be a priority.
I would save all the power stuff for last. Get sticky rubber, good suspension, LSD, then think about power if you've got spare money you want to spend.
And if your budget is tight, cruise the classifieds for used stuff. Wheels especially - I got kosei K1s with good rubber for 800+shipping, and recently a set of Dforce LTW 17x9s for 700+shipping.
I still want the car to be legal for local competition and our local Match Tour.
That is interesting, I guess when I have the $$ in hand I will figure out what tire to go with based on availability.
Thanks for the info on the aFe, didn't know that. I have power stuff planned last for sure, don't really care about it right now. Priority right now is wheels/tires then suspension so I can get to the driving.
Hmm good deals, I'll keep an eye out.
Thanks!
These don't seem too bad for $661 shipped. Edit: shipping weight listed on Amazon is 26 lbs.
Too heavy, that's a deal breaker imho.
For seats, I picked up a pair of F1 Spec Type 5's for $400 shipped. Build quality is pretty good actually and the seats fit great. For reference I'm 5'8 145# 30" waist. Check my project log for pics.
For battery, etx20l. 330+cca's and can be pick up at advanced auto for $60-$70 after coupons. All just rebranded deka batteries.
Seats, not sure but they were pretty light. Recaro SPG reps, fiberglass back. I'd put them at 10-12# or so, I could probably take one out and weigh it.
Battery, I believe 15#.
Awesome man, thanks for that. Looks like a great deal for those seats, so these ones:
http://www.f1spec.com/ty5sef1.html
Wonder how long that deal will be going, maybe I'll just grab them hehe. Checking out your project now...
BTW, how did you mount the seats, what brackets, hardware, etc?
BTW, I have my first mod complete. Glow in the dark Batman duct tape to seal up the tears in the leather seats
Now my kids have been calling the car the "Batmobile", and so it shall be named going forward!
Yup exactly those. Shipping was quick since they're in Cali. I used evo sport seat mounts and bought sliders and side mounts from F1 for $50 for both sides. For passenger side I replicated the evosport seat mounts on a mill.
So like this floor-->seat mount-->sliders-->side mount--> f1 spec seat.
Stoptech Street performance pads will do fine in autox and light track duty. They aren't expensive either.
Apex Arc 8's in 17x9" arrived:
Also started on some maintenance work, spark plugs and valve cover gasket. Pulled the coils off the plugs to find the spark plug holes filled up with oil...Must be time to change the plug seals
Yes there is a spark plug in there:
Seals for the plugs will come with the Valve Cover Gasket set
The 6 little dudes at the top of the picture
Stupid valve cover gaskets. It wasn't until I'd ordered my second non-vanos gasket set that I went in and discovered that realoem has the wrong part number for the '92 325is gasket set, grr.
I find they don't seal very well and have taken to smearing RTV on both sides. Next time it leaks I'll be putting a second washer under all the fasteners to clamp the gasket harder, see if that fixes it.
Thanks Kale I had the gasket set already (including the spark plug seals) and got it all finished up last night. No external leaks anymore around the cover gasket. I'll pull a couple coil packs in a couple weeks to make sure those sealed up fine. Not too worried about it anyways, even with all the oil in there the car still ran perfectly fine!
Yea I've seen some gaskets with RTV all the way around. I just RTV'd the half moons and seams up front, see how it holds up, so far so good.
LSD confusion (hah!)...I want the e36 diff with the 3.15 fd right?
