Well, I have been collecting stuff for my e30 swap for about six years and I hate to see it go, but I have medical bills to pay. I beat cancer, but it has cost me a lot of money and the bills need to get paid. I will answer in the order I get things as fast as I can. (which is not always fast, sorry) I can get pictures of anything, but most of it is new.
I hate to do it, but I can't afford the paypal fees, so I would appreciate enough extra to cover them. I will ship it anyway you want if you are paying the bill. I live north of Seattle, in Washington state.
I have a lot more to come, full suspension, big brakes, mt2 kit, but I am holding off.
S50 & ZF 5 Speed – About 78,000 - $2500 plus shipping. (this is basically a complete motor and transmission with harness, ecu, pretty much all bolt on stuff, I stripped it to the block, but have everything. Car VIN available by request)
Turner/Conforti Stage 3 Kit (+57hp / +30ft-lbs) $2400 new $1500 plus shipping ==SOLD==
- Schrick Cams
- Euro HFM
- 24 lb injectors
- Matching High Performance Chip
NGK BKR6EIX Spark Plugs - new - (was $42+shipping) $37 shipped
BavAuto High-Performance Ignition Coil Set - new (was $275+shipping) $240 shipped
Oxygen Sensors - new (was $204+shipping) $180 shipped
Camshaft Position Sensor - new (was $128+shipping) $115 shipped ==SOLD==
Crankshaft Position Sensor - new (was $82+shipping) $70 shipped ==SOLD==
Knock Sensors - new (was $114+shipping) $100 shipped
ARD Underdrive Pulleys - new - $150 shipped - ==SOLD==
Silicone Vacuum Hose Kit - new (was $30+shipping) $25 shipped
ARP2000 Head Bolts - new (was $185+shipping) $165 shipped ==SOLD==
Elring Head Gasket Set - new (was $195+shipping) $180 shipped
Valve Spring Retainer Set - new (was $280+shipping) $260 shipped
Valve Keeper Set - new (was $84+shipping) $74 shipped
Beisan Single Vanos Seals Repair Kit - new (was $30+shipping) $25 shipped ==SOLD==
Beisan Single Vanos Rattle Repair Kit - new (was $30+shipping) $25 shipped ==SOLD==
Oil Pan Gasket set - new - (was $63+shipping) $53 shipped ==SOLD==
E36 Euro Oil Filter Housing - $240 plus shipping ==SOLD==
Euro cooler and lines - $140 plus shipping ==SOLD==
Bavarian Auto FCX2 Code reader and reset tool - new (was $149 + shipping) $125 shipped
UUC Oil Center - new - $100 plus shipping NOT AVAILABLE FROM UUC CURRENTLY
Prosport Gauges - new BLUE/WHITE 52mm series - oil temp, oil pressure, & water temp (was $154+shipping) $140 shipped
BMP e30 Gauge Console - new (was $85+shipping) $75 shipped
UUC Stage 2 Lightweight Aluminum Flywheel with clutch and pressure plate $550 plus shipping
- M5 Clutch
- M5 Pressure Plate (The clutch is a Sachs, BMW part # 21212226593)
E36 325i slave cylinder - new (was $59+shipping) $49 shipped
E36 325i UUC Stainless Steel Clutch line - new (was $29+shipping) $25 shipped ==SOLD==
AKG Trans Mounts - - (was $75+shipping) $65 shipped ==SOLD==
UUC Clutch Stop - new - $15 shipped ==SOLD==
Throughout Bearing - new (was $45+shipping) $37 shipped ==SOLD==
Mishimoto Radiator - new (was $340+shipping) $240 shipped ==SOLD==
Aluminum Thermostat Housing - new (was $30+shipping) $20 shipped ==SOLD==
80 degree Thermostat - new (was $18+shipping) $14 shipped ==SOLD==
Spal 16" Pusher Fan 2047 - new (was $150+shipping) $135 shipped
80/88 Degree Temperature Sensor - new (was $25+shipping) $20 shipped ==SOLD==
Samco Silicone Radiator Hose set, blue - new (was $100+shipping) $80 shipped ==SOLD==
Silicone Vacuum Hose Tubing kit, blue - new (was $85+shipping) $60 shipped
Here is the list of the main swap parts I have. Some of parts will be listed in the performance parts thread instead of here, like the cooling system for example. New parts are listed, the rest are in at least good plus condition.
E34 oil pan, dip stick, and tube - $130 plus shipping ==SOLD==
E34 throttle cable - new - (was $31+shipping) $25 shipped ==SOLD==
E28 M5 motor mounts - new - (was $65+shipping) $55 shipped ==SOLD==
E36 motor mount arms - $55 shipped
S50/e30 wiring harness adapter - $150 shipped ==SOLD==
413 red label DME - $80 shipped ==SOLD==
Swap DME Mount Adapter - new - (was $31+shipping) $25 shipped ==SOLD==
AKG Trans Mounts - new - (was $75+shipping) $65 shipped ==SOLD==
1492mm e36 Driveshaft $100 plus shipping ==SOLD==
2.79 LSD - best offer
3.25 LSD - best offer
Correct Swap Brake Booster $75 plus shipping (e21 if I remember right) ==SOLD==
The following is a custom fitted exhaust system. For the most part, this should bolt up to your swap and exhaust mounts eliminating the need to fabricate mounting for the swap. This setup is arguably as good as you are going to get for your swap. Excellent performance boost and that kind of Euro sound without the heavy rasp. This is worth every penny!
E36 Euro headers
E36 Euro midpipes
E36 Stromung Stainless catback (all e30 ready) $1500 + shipping
Racing Dynamics e30 Strut Bars - $200 plus shipping ==SOLD==
e36 EXHAUST - mid-pipe and catback ODB1
I bought the exhaust to get the mid-pipe for my s50 conversion and ended up going with a euro exhaust, so I never used it. Supposedly, the catback has some miles on it but is good. The cats are supposed to be new, or newer. But honestly, I have never heard them running or used them. With the oxygen sensor they should go about four hundred, but I would take $250.
e36 M3 DASH - dash, gauges, heating, lights, etc. $250 - ask about any miscellaneous modules from under the dash
e36 HEAD LIGHT ASSEMBLY - Drivers side with bulbs $60
e30 MSDS shorty HEADERS - m20 ceramic coated $165
First round shipped, some stuff updated.
Best offer on strut bars by tomorrow night takes it. $200 plus shipping takes them right away. Currently $175 plus shipping is the best offer.
Thanks,
KJ
Has that exhaust setup been mounted on a e30? I have a customer looking for a nice 24v e30 exhaust. Needs to fit real nice though
I bought these from one of the guys on R3V that had one of the nicer swap cars on the forum there, tons of high-end upgrades. He ended up parting the whole car to move on to another project. He had the euro stuff shipped in from Europe and had o2 bungs welded into the midpipe and had the Stromung adapted to fit into an e30. All the work was professionally done and was not cheap. His description of the exhaust was, "Really sounds SICK in person, and no bullshit get compliments on my exhaust note all the time. ABSOLUTELY no rasp, NONE. LOVE it. Quiet rumble at idle, nice tone around town, then all hell breaks loose above 4.5-5k WOT." I never got a chance to install them. This was setup was one of my prized acquisitions.
gotcha, Im sure it would be great but shipping cross country may kill it. If you wouldnt mind PMing me best price shipped to CT 06405 that would be great.
How much for just the Schrick cams?
What suspension setup do you have? If you are ready to bust out with that info!
@CRISMACSTUDIO
PM'd about the radiator and thermostat housing
It is not for sale, but this is what I have. I really want to get all this in still.
H&R Springs
Bilstein Struts
UUC E30spec Sway Barbarian Sway Bar Kit - new
Treehouse Racing Eyeballs - new
Lemfoerder control arms - new
e36 Lemfoerder outter tie rod ends - new
e36 steering rack
AKG steering rack conversion kit - new
Racekids Cross Brace - new
AKG Street complete bushing set - new
Wilwood/RPI Front Big Brake Kit
Bavarian Autosport Ultimate Brake Rotor Set, Rear - new
Hawk Ceramic street pads rears - new
UUC Stainless Steel Brake Lines, front & rear - new
ATE Super Blue Racing Brake Fluid - new
MTECH2 Body Kit
Nardi Blackline Steering Wheel & adapter
Smoked Euro Smileys, H1 conversion with LED city light conversion
Euro Grills
UUC Pedal Set - new
Maybe someday!
PM sent regarding Stromung exhaust.
Interested in the Euro Filter Housing Lines and cooler if its still available....PM Sent
Some stuff sold. Some prices updated. Thanks, KJ
sooooo, is there any chance i can get those front brakes??
