I have been planning to put some poly sub frame bushings on for a while now as a preventative and performance mod. The indy shop I was going to said that their distributer (a major VW, BMW distributer) said these have a tendency to fail/crack/squeak very quickly if used in a year round DD especially in New England winters. They said go OEM or full aluminum...I said.
I put a call in to Bav auto and they told me no failure problems to speak of but the squeak may become an issue because the year round use will wear out the lubricant. I thought that this would be a problem with a more mobile suspension part like say, control arm poly bushings (not my plan). If I only do the SF bushings then they really should not experience that much movement right? Does anyone have them on a DD and if so what's your experience with the longevity of these bad boys.
Don't have them yet but longevity is excellent on these as they are in a static position (that is, non-rotating, only side loads). For the same reason, squeaking isn't an issue either. You generally don't even lube the SF bushings when installing except for MAYBE a little bit on the outside to help them slide into the subframe.
The same set(s) have been on both of my cars since 2004, and they were daily drivers in Ohio (until 1-1/2 years ago). While the gray car saw very limited winter use__only on clean/dry roads__the black car was, as is still, my daily driver.
There is no downside to the urethane subframe bushings__unless you have particularly sensitive hearing, and drive a Coupe__as in this application, they netiher slide nor rotate, limiting wear and zero chance of squeaking.
I have never recommended they be used in our front or rear suspensions, unless you're a dyed in the wool track rat, or have a particularly loud exhaust__for obvious reasons...
Awesome, thanks guys. You have set a restless mind at ease!
I've been running PowerFlex Blacks in my E36M for years and it's handled many Ohio winters of DD duty with no issues. I'm running just about everything PF on the car, the FCABS I do grease about once a year, the rest of them I don't think I've touched for year or two.... so now I'm going to slather them all in a coat of grease since I'm thinking about it. No serious squeaks from them to speak of, no issues with cracking, nothing but a nice tight car.
-James
You will not regret the poly subframe bushings. You will however regret doing RTAB's in poly. I have a pretty loud exhaust so I never hear them while cruising, but on a rough driveway they are very squeaky.
You can re lube them. They make a needle type injector for just this purpose I think. In any case mine used to squeak really bad, but apparently over time they can loosen up slightly and start squeaking because the inner sleeve starts to move a bit. Try re tightening them.
Suspension: Bilstein Sports, GC Coilover conversion, IE Subframe Bushings, IE RTABs, M roadster sways, M roadster front control arms, M roadster Front calipers/hubs.
Engine/Driveline: M54B30 intake Manifold, Dinan CAI, ZHP Cams, Headers, Underdrive pulleys, Conforti Software, 3.46 diff.
I've had poly subframe bushings on mine for a while now, probably over 10,000 miles at this point. I had a set of the bad batch IE greens, but then switched to Powerflex Purple and have had no issues since. Yes there is a bit more NVH transfer, but the peace of mind in knowing your chances of trunk floor failure have decreased makes it worth it.
Buy a tub of this & use it generously when assembling.
http://www.energysuspensionparts.com...shing-Lube.asp
little squeak issue from the PF FCAB in the beginning due to not using enough grease but smooth sailing since
I ordered the black bushings shown on IE's site:
http://www.iemotorsport.com/bmw/Z3-s...bfrmmount.html
But the bushings they sent are green.
Is there any difference besides color?
Now I see, they are a very dark green in the link, so dark I mistook them for black:
The ones I got are a lighter green, like the right one here:
attachment.php
But it must the same green with different lighting.
Just installed the IR SFB in my '97 Roaster.Boy did it make a difference,rides better,handles better.tightened up the rear end big time.I am very happy with the results!
Sent from my iPhone using BF.com
It was fairly extensive, I did the eccentrics and rtab bushings at the same time. I used the pipe tool and a propane torch after the "subframe" was out.
It's a Hybrid--Burns Gas and Rubber
I had to use very little heat from the propane torch to get the old bushings moving,I did not burn any of the coating on the subframe,used the pipe tool,worked very well.
Sorry if this is a necro bump.
I think I may be talking to the same independent BMW tuning shop that the OP did, they are being very negative about this mod... I'm glad I found this thread, I'm going to go ahead and get a pair of these bushings ASAP. What's everybodys favorite make/model of bushing? I'm seeing a lot of different types being mentioned here.
Just out of curiosity, I would love to hear what their negatives were on this. As far as I'm aware the only negative I have heard so far is a slight increase in driveline noise transmission to the body.
I would say almost no negatives for this, only positive things in my opinion so far.
That was funny. Asked a fellow car guy at work what he thought about this whole mess, showed him the AKG bushings that Pelican sells, noticed that they have "75D" and "85A" and I asked what that meant, he comes back with this a moment later
75D basically feels like solid plastic...
Z3M Racer '99 M Roadster
