Results 1 to 11 of 11
Thread: List of 210mm, large case differential BMW's
    Nov 2010
    Staten Island, NY
    e46 M3
    I've been looking for diff alternatives for my E46 M3. It has the large case, 210mm differential, with 8 bolts on each side. (Medium, 188mm cases have 6 bolts.) Basically it's all the "big" 6 cyl, the v8 and v12 cars. I started compiling a list of other models with the large case. Originally I wanted to find a cheaper alternative to find a 3.91 or 4.10 rear, it's been tough to find and I'll probably just end up purchasing a new, built unit with a true LSD. Anyway I figure that a list like this could be useful to someone else so why not post it up? Feel free to confirm or correct me, also if you know the correct gearing I'll update it as necessary.
    Large 210mm Case BMWs:
    -E24 M6
    -E31 850 (auto 3.64)
    -E34 M5 before 6/94= 3.91
    -E36 Euro (w/3.2l) M3
    -E38 730, 740 (V8s), 750 (v12)
    -E39 535, 540, M5 (all V8)
    Dec 2010
    mv. ca.. oooh c
    blk 740i/ 325is - 95's
    What are e65 / e66 diffs? Can we use them?
    Kentucky
    '03 Z4, '06 Forester
    E34 540 and E32 740 and 750 also used the large case diffs; not sure of the ratios.
    Raleigh, NC
    98' M3/LS2; 97'' 328i
    Bringing this one back. I'm interested to know the 210mm diff differences and parts interchangeability.
    Jun 2010
    Reykjavik Iceland
    ALPINA B10 BITURBO
    AFAIK,,,, these ratio are available in a 210mm casing
    and here are some cars that have these ratio
    2.65... US 850 ONLY (afaik)
    2.93. E32/E34 V8 4.0 and 850 CSI and E23 745
    3.07. E28 M535 and E23 745
    3.15 E32 750 and 850
    3.23 E34 M5 3.8 6g and E36 Euro M3
    3.45. Euro E34 535 and E32 735 and E23 735
    3.64 Euro E34 535 E32 735 and US 850 (maby also US 750 E32)
    3.73 Euro E32 735 and US E34 M5 and E28 M5
    3.91 E34 M5 and Euro 735
    there may be other cars with these ratio ,,but this came in my mind
    Sveinbjörn Hrafnsson
    E30 CABRIO V12 M70B50 ///
    ALPINA B10 BITURBO 346 @ 507
    ULTIMA Evolution
    Contacts
    http://alpina.123.is/pictures/
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    bumping this because it's great info!
    Dec 2012
    Los Angeles
    1996 M3, 2016 GMC Canyon
    I can get a 97 740iL diff for 20$ if I go pull it. Assuming its a shit ratio, but I can buy different ring and pinion for a few hundred and a mount kit from rallyroad and be good to go? Or only the e32 750i's?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    You are not the first person to ask such a question. If the answer was yes, you would be reading about it.
    Aug 2016
    UAE
    1998 BMW M3 Coupe S50B32
    What about the E46 M3 and the E9x M3 and the E60 M5. What size diff do they have?
    Quote Originally Posted by Hasan Shaikh View Post
    E46 M3 diff size is literally in the first sentence of this thread
    E92 M3 and E60 M5 are 215 diffs and not easily swappable with anything else
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    here worldwide list E32, all diff sizes:
    730 iA from 09/88.......: 4.10
    730 iA Switzerland......: 3.64
    730 iA Switzerland from 09/89....: 4.10
    730 iA Australia /Japan..........: 4.27
    730 i M60 engine..............: 3.15
    730 il M60 engine.............: 3.15
    730 iA M60 engine.............: 3.23
    730 iAL M60 engine............: 3.23
    735i..........................: 3.45
    735 iA........................: 3.45
    735 iA from 09/88.............: 3.91
    735 iA Switzerland from 09/89.: 3.91
    735 iA Australia..............: 3.64
    735 iA Australia from 9/89....: 3.91
    735 iA USA / Canada / Japan...: 4.27
    740iA.........................: 2.93
    740iAL........................: 2.93
    750iA.........................: 3.15
    750iAL........................: 3.15
    750 iAL USA / Canada / Japan..: 3.64
    other cars ratios here from http://www.vinesauto.com/diffratio.htm
    pics/dimensions, bolt sizes/pattern
    http://www.bimmerboard.com/forums/posts/793828
    http://www.bimmerboard.com/forums/posts/794017/
    BMW Differential Tutorial, with pics. https://www.bmwfanatics.co.za/showthread.php?tid=1374
    Type 188 cars:
    All E36 models, except the 3.2lt M3.
    All E30 6cyl models.
    All E34 models, except the M5 and 540i.
    All E32 6cyl models.
    Type 210 cars:
    E46 M3 and E36 4door M3.
    E34 M5 and 540i.
    E32 740i and 750i.
    All E38 models.
    E39 V8 models, could be all models but not sure.
