Finally got the car back from Zury's after nearly a month. He got backed up and took longer than planned, but I am certainly happy with the end result.
Went with a 24x4x12 which has to be shoehorned in this car if your running a electric pusher fan. Had to be angled to fit in. Also the biggest hurdle for Brian was the need for my Motion underpanel to have its supports installed which are directly in the way of the charge piping from the turbo. He worked it out and still was able to fit a 3" intake pipe in place of the oval pipe I had before.
I lost my brake ducts but i'm ok with that, they aren't functional on this car anyway at least from the factory.
Now to decide if I want to keep the pipes polished, powdercoat them red....or black. Oh the choices.
The bottom line though is the car is pulling like a beast, best I've ever felt it. Just like Rukman said this was the upgrade that unleashed the beast when your upgrading the TT stg II kit piece by piece.
the pics
As I picked it up
clears the underpanel supports
Transition to 3"
Installed all new fender liners and hardware. Had to be a little bit of trimming on both sides to clear the charge piping but it was very minimal, all back together
After a great drive today, cold side charge pipe was totally cool to the touch after the drive....its working!!!!
I WILL HAVE THE CHARGE PIPING AND INTERCOOLER FROM MY TT KIT FOR SALE VERY SOON. COLD SIDE WAS DONE TOTALLY CUSTOM, HARD PIPED AND VBAND FOR TIAL BOV.
Beautiful work!
May I ask, who did the work? Is this a shop?
Did you start off with a trm or technique tuning kit? I am trying to decide on what kit to go with. Great looking result, love your car.
1998 E36 M3
Dakar Yellow
Can't wait for my 31x12x4, I wish I had a fabricator close to home that did good work like this.
So there is a huge difference from before to now?
As in will show on the dyno or just a feeling its doing better pull after pull because it's not getting heat soaked?
I started off with an older TT kit, the old kits had a smaller intercooler i'm pretty sure i was pushing way too much cfm for it.
I'm sure it would show on a dyno, it felt very noticeable to me. Heat soak will also be reduced but based on my ever so NOT accurate butt dyno it is pulling much harder and stronger to redline.
Your car is probably the cleanest E36 I've ever seen! It looks so good!
OLD
E30
636whp
1/4 mile: 10.91@144.38
http://www.youtube.com/watch?v=L_f7fUVqblI
NEW BUILD
335d
520whp
635wtq
120.51mph trap speed
Very nice and clean
Looking good now go back to MIR and dont break it this time..
E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
*RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
Very nice!
I've been thinking about picking up the motion Motorsport panel myself. Probably will have to mod it or the piping to get the brackets to fit.
Any dyno action planned?
Dyno's are boring, get trap speeds.
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
Looks great Matt!
TT stage 2 is under the sub-frame piping?
Notice any drop in pressure going from the 3" to 4"
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
Very nice Matt!
I would go with black powder coat...
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
Keep it polished to help reflect some of the heat.
I left the stock mesh on the bumper to protect the IC and make it look not as polished loud.
I drilled small holes and used small zip ties to hold the mesh after I cut back the opening to fit my IC. Looks good to me, but my car is a driver, not a show car.
| 1997 Estoril M3 - TURBO - || GT35R | 8.5:1 forged internals | ARP stuffs | SS Oring Block w/ elring | Fully balanced & blueprinted 3.3L S52 | Nick G Tuning || 46mm Precision gate| 62# injectors | Dual Walbro's |Goal: 600+ whp pump gas reliable 10 second car.
-2007 335i Sport Package
