Hi there
I've got an error message when trying to read my ZCS/FA from the KMB. The message is
Central Coding Key is Faulty
COAPI-1081: faulty GM-key (C1)
FFFFFFFF
The setup has been working fine for many weeks, reading and coding modules. I was attempting to code my CVM (vert module) which threw a fault. I get the error messasge reading the KMB. I do not get the message reading the EWS. I restored the CVM to it's original state using the EWS read and I still have the warning. /car is an R52.
Any help please?
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
What version of programs? And what EDIABAS?
Thanks very much for replying and for any info or remedy you can share.
NCS Is at V3.1.0 [COAPI 3.5.1 b]
EDIABAS is at V6.4.3
SPDaten are at V48.1
I have this combination of EDIBAS and NCS becuase the CD that came with my D+KCan had me install software in a sequence that gave me this particular setup.
