about tire size, wheel width and suspension set-ups. I'd like to paste them into the tire/wheel sticky to make it more useful. I need your help, guys.
Edit: I added my car to the sticky so you can get a feel for what I am looking for. The more specs, the better, but I'll take whatever I can get.
For reference, in case you don't see it: http://forums.bimmerforums.com/forum...-Wheel-Offsets
Thanks,
Terry
Stuff. I got stuff.
Do you have any static shots, where the car isn't moving? Your pic has the car leaning a bit making the gaps look larger than they probably really are.
Thanks,
Terry
Thanks to everyone, so far. Keep 'em coming. As you can see, I am deleting the posts in this thread once I use them. That makes it easier to keep up on the xfers and where I last left off. Please do not post follow-ups here. Thanks
Also, I may not use every photo provided. I really prefer side shots to maintain consistency, whenever possible.
Stuff. I got stuff.
Read under "Reason" on each post or my last post, the BOLD text. Nothing "fishy" is going on. sigh.
It said:
"Thanks to everyone, so far. Keep 'em coming. As you can see, I am deleting the posts in this thread once I use them. That makes it easier to keep up on the xfers and where I last left off. Please do not post follow-ups here. Thanks
Also, I may not use every photo provided. I really prefer side shots to maintain consistency, whenever possible."
Stuff. I got stuff.
Ok, understood.... fortunately I saved the info I was looking for but for future reference, you never know when someone's reply (that you've already benefited from) could benefit a future member who's looking for similar information.
Thank you though for the explanation and removing any paranoia I had 5 minutes earlier
Ok, here are some old photos. I have changed the setup but this may be of use for your thread. I will get some newer photos and upload them soon but it a different setup. So I think both setups will be usefull.
17x9 DForce LTW5 41 offset E36 wheels, 7mm spacer front, 30mm spacer rear, camber plate set at -2.9 front. Dunlop 255/40x17 Star Spec tires. Bilstein Sport shocks and struts, H&R Sport springs.
http://www.flickr.com/photos/92777207@N05/8592848188
http://www.flickr.com/photos/92777207@N05/8591747115
http://www.flickr.com/photos/92777207@N05/8592843292
Thanks, Guys! Keep 'em coming.
Stuff. I got stuff.
Bump, more cars please! I need a couple more Z3s, both 6s and 1.9s, if possible. Also looking for any wheels that aren't yet represented. Please post a side shot of your car and description.
Thanks,
Terry
Stuff. I got stuff.
Koni SA - 295 Rear 245 front (Tires) Wheels stock (of course) and 5mm spacers up front. No spacers in the rear.
DIY/Project Links:_TC Kline D/A & Suspension Refresh_|_Oil/Engine Cooling Options / Install_|_
Dinan/Fikse FM-5 Build_|_Stereo Install_|_HID Retrofit_|_
Factory size wheels and tires.
H&R coilovers
No spacers
Another overrated set of Race CCW Classics
Suspension- KW V3 , Rear springs TCK 500lb; no adjuster
Wheels/Tires:CCW Classic 17x10 et43 [Spacer: F-25mm R-20mm] 245/40/17 Currently small spacer in the rear in order to fit larger lips in the near future
1997, 2.8.
AC Schnitzer Rennsport Type I 17" 3pcs 10J ET33 (stepped lip 2,5") rear and 8J ET33 (stepped lip 1,5") front.
Tires 245/40/R17 Pirelli P-Zero Assimetrico rear and 225/45/R17 Pirelli P-Zero Nero front.
Stock suspension.
BBS RE 8.5 et35 front with 235/40/18 and 9.5 et22 rears with 265/35/18
Thanks, everyone! I think I caught up.
I wanted to post these pics since I'm only half done, so you can see the comparison better. The front end is still stock while the rear springs have been replaced with Eibach springs (1.5" lowering). The shocks are Bilstein Sports all the way around. Eventually, I will put the rest of the Eibach set on the front. I'll also be correcting the rear camber problem.
AC Schnitzer Type I 3-piece
18x8 et35 + 10mm spacer - 225/35r18
18x10 et13 + 10mm spacer - 295/30r18
check. TY
ah sorry cocked it up, they are Type II, not Type I
Wheel: Miro 8.5, 9.5 x 18
Tire: 225x40, 265x35
Coil spring: H&RDSC02876.JPGDSC02882.JPG
Bump, looking for more cars/wheels!!
Thanks,
Terry
Stuff. I got stuff.
