The specs: 1990 325ic with m50NV 3.0liter VEMS 3.6 ECU PRICE - $10000obo
Body
New convertible top
New tension straps
new seals - a bunch of random ones
resealed heater box
new blower motor
new blower resistor
new heater core
new si board
new odometer gears
new pioneer radio with Iphone interface (very important for the wife)
new fog lights
new front turn signal indicators
new left and right grilles
new kidney grille
new is lip spoiler - with clips
Windshield washer pump - grommet
Windshield washer nozzles
Front turn signal lenses
Led light strip in the on board computer
Led lights in the trunk
Led lights in glove box
Rear view mirror from 03 325 - this has a garage door opener built in to it. It also auto dims which is really nice when the top is down at night
E36 m3 light up shift knob - this lights up in a red that matches the interior
New shift boot
Battery - interstate with 5 year warranty
engine
stock block - cleaned, decked and painted black - deck was shaved by .5mm to increase the compression ratio
rotating assembly - m54b30 crank, rods, and pistons
bearings and rings have been replaced
cylinder head - milled and cleaned - replaced valve guides and seals - new lifters
I have an extra intake cam but I didn't use it... This will go with the car
new chains
new guides
new oil pump
new water pump - metal impeller
new thermostat
NGK QUP spark plugs
new coil boots
oil filter housing off of a m54b30
updated power steering pump from a late e46 to increase steering assist
stock mechanical fan - stock radiator
New parallel flow condenser
new spal fan
new aux fan switch
new a/c lines - a/c was switched to r134
new belts
new belt tensioners
Tuned by me with a 405 dme and ostrich 2
Injectors - high flow 280cc - I have the flow chart for these
New fuel lines - including the ones around the fuel tank
New breather hoses
Vibrant air filter
Belts
Fan clutch
Drained and cleaned the inside of the fuel tank
Fuel filter
suspension
I'm annoyed with typing new so i'll just list the parts I replaced and say if it isn't new.
Eibach sport springs
upper front strut mounts
spring pads
KYB shocks
control arm bushings
motor mounts - green 535
transmission mounts
rear subframe and trailing arm bushings
differential bushing
rear shocks
upper rear shock mounts
Driveline
92 525 zf transmission
stock clutch
throw out bearing
pilot bearing
slave cylinder
master cylinder
clutch hose
z4 2.5 shifter
shifter bushings
guibo
e83 front driveshaft section - this is needed because the 525 transmission has a large guibo and the stock 93 325 driveshaft has a small front section
e36 rear driveshaft section
center support bearing
OVERVIEW:
The bad - could use new seats - The seat frames and foam are in great shape but the leather covers should be replaced
The paint isn't in great shape - someone did a quick spray on it and didn't prep it correctly.
only the seat heater on the driver seat works. I would fix the passenger but I don't have any extra heating elements to install.
The brakes are still in decent shape and have about half their life left. The tires are also in pretty good shape. The dash is crack free and looks great when there's not a cover on it.
I will be rolling the fenders on Wednesday once my new roller arrives.
I'm sure I have forgotten a ton but i'll fill it in as I remember.
Email me or call me - Devin1205@gmail.com or 480-353-7202
Last edited by DevInAz; 06-11-2013 at 12:56 AM. Reason: forgot to list some things
Bump
bump. offers?
Pics of engine or under body?
Here is an update for this car.
The latest things I've done to the car are:
Full front and rear brakes, including pads and rotors
Standalone engine management by VEMS. It is a 3.6 unit that I installed because we couldn't get the factory management to run this engine correctly.
Rear seat cover from VAC motorsport I think. I bought this from someone online
Front BMW seat covers
Front and rear Arc audio speakers with internal tweeters
I still need to get under hood pictures and new interior pictures.
Bump
That's a lot of money. 0_o GLWS
bump. Offers? questions?
Anyone know how to change the price in the thread title?
