Hello All,
I have just purchased an X3 for my wife.
It is 2004, 3.0 and red/black and Auto with 80000 miles.
I see a lot of talk about X5's in this section, but not so much in X3's.
As always after you buy a car, you want to refresh all fluids and other worn parts.
Here is my question, what are the intervals of changing fluids and other parts.
Any other info, such as part numbers, fluid types, are always appreciated.
Maintenance Schedule and Information:
Rear & Front Differential Fluid - BMW X0 or RedLine 75w-90 - about 1L each needed
Transfer case Fluid - TF0870, SAE 75W - BMW# 83220397244 - 1L needed
Transmission Fluid (Green label) - Dextron 6 - BMW# 83220397114, update with BMW# 83220397114 (4L jugs) - about 6 quarts needed
(Green label is GM transmission, BMW says lifetime, however GM says 60k miles in their cars, so you decide)
Transmission Filter - BMW# 24117557070 - kit comes with gasket and new pan bolts
Brake Fluid - DOT4 Synthetic
Coolant is BMW blue
Power steering Fluid - BMW# 83290429576 - 1L needed
Microfilter - BMW# 64319071935
Engine Air Filter - BMW# 13721744869
Serpantine belt - BMW# 11281706545
AC Belt - BMW# 11287512762
I will update this first post with all the info i collect from you guys for the next person with an X3!
I am still looking for BMW checklist S92-260
I think this is a pretty good summary here:
Every 60,000 miles:
Trans case fluid
Differential fluid, front and rear
Coolant fluid
Tranny fluid
Serpantine Belt
AC service??
Every 30,000 miles:
Brake fluid
Replace Air Filter
Replace cabin filter
Every 80,000 miles:
Rotors and Pads
Every 7,500 miles:
Oil and filter
Clean air filter
Here is about OEM recommended intervals:
"Only after disaster can we be resurrected.", Tyler Durden, Fight Club.
CURRENT
2002 M3 conv - '07; 2006 k1200s - '09; 1998 M3 CB coupe - '10; 2004 X3 - '13
A lot of the motor stuff will be the same as any E46 Non-M.
rear diff fluid is BMW X0 not sure on weight but I will check
front diff is also bmw xo fluid
transfer case is ATF hold about 1L
transmission is going to be DEX 6 but.. make sure you check the sticker on transpan first, bmw states that its lifetime fluid but we change at 60k'ish or recommend to customer and filter gets changed at 100k'ish
power steering is ATF dex 3 fluid
brake fluid is dot 4, change every 2 years.
coolant is coolant but I wouldnt mix blue BMW coolant with others, change every 4 years.
engine oil, 5w30 castrol syn (bmw branded only, do a search for this) change every 15k according to bmw, I would change every 7.5k if it were mine at the max.
here is a break down of the maint light.
from zero miles
15k oil service (change oil, filter, micro filter, check car)
30k inspection I service (same thing except more checks)
45K oil service (same as 15k)
60k inspection II (same as inspection I but add engine air filter, lube all hinges and inspect parking brake shoes in rear.
75k oil service
spark plugs at 100k
fuel filter is built into the tank and is major expensive to change (correct me if I am wrong on this for 04 model.
well there you go
Level 1 Certified BMW tech.
Crazy to go 15k as recommended by BMW. 7.5k intervals on synthetic for all of my BMWs.
Yes, I would never go by manufacturer recommendation.
But my question lays deeper, I am talking about intervals for suspension, and other parts.
For example, I know it already needs thrust arms, is 80k good interval?
What about shocks?
Or am I being too an@l aboutt this?
Sent from my DROID3 using Tapatalk 2
CURRENT
I have been pretty lucky as some of my BMW's are now over 250,000 miles. I do my oil every 10,000. Always synthetic and a German oil filter. I use my speedometer as a reminder; When it gets 130K, 140k, etc... On the power steering. I use a turkey baster(I believe its called) and remove all the PS fluid and refill every 30-40K and never any issue I use synthetic blend trans fluid. 90turbo1 is on the money on the info. Wish you luck!
as far as power-steering fluid, i think it is better to unbolt the bottom hose from the steering rack and drain that way, because then you drain most of the fluid from the pump and reservoir. then just make sure to get new crash o-rings.
so can someone chime in on the bushings, ball joints, vanos rebuild, various gasket intervals?
sorry for so may questions, i never owned M54. only S54, which has a LOT more maintenance requirements.
is there a BMW scheduled maintenance list somewhere for X3? (i have one for k1200s and e46 M3)
Here is my list so far:
Front Thrust Arms
Valve cover gasket set
http://www.ecstuning.com/BMW-E83-X3-M54_3.0L/ES197388/ - transfer case fluid
http://www.ecstuning.com/BMW-E83-X3-...rior/ES251602/ - jack pads
http://www.ecstuning.com/BMW-E83-X3-...rol/ES2568301/ - microfilter
http://www.ecstuning.com/BMW-E83-X3-...ngine/ES10304/ - engine filter
http://www.ecstuning.com/BMW-E83-X3-...gine/ES263047/ - Oil, Filter, drain plug, O-rings
http://www.ecstuning.com/BMW-E83-X3-.../Brakes/ES111/ - Super Blue Brake fluid
http://www.ecstuning.com/BMW-E83-X3-...ngine/ES10334/ - Serpantine belt
http://www.ecstuning.com/BMW-E83-X3-...ngine/ES10333/ - AC belt
http://www.ecstuning.com/BMW-E83-X3-...rain/ES263484/ - differential fluid
http://www.ecstuning.com/BMW-E83-X3-...ing/ES2550608/ - Power steering fluid
http://www.ecstuning.com/BMW-E83-X3-...ion/ES2523867/ - Transmisison fluid, Filter, Gasket
Some of the fluids are from RedLine, is that going to be OK, or do i absolutely have to use BMW ones? anyone do blackston reports on RedLine fluids?
As far as ATE blue brake fluid is because it is easier to tell when it is fully changed. I altetnate the blue with gold fluids to make sure the brake fluid is completely new.
CURRENT
Thanks , I have read some good service information. I to have have purchased a '07 X3 for my son and I am new to owning a BMW, is there a way to reset the service light ?
Also someone recommended Castrol but BMW certified oil, is this a different type or grade than what is normally sold ? Any suggestions or help would be greatly appreciated.
That 15,000 miles by BMW is for the original owner since it includes FREE MAINTENANCE (AKA lack of maintenance by BM Trouble U) with the cost of the car. Think of it 3 free oil changes (45,000 miles) versus 6 oil changes @7500 now you will know why it cost effective for BM Trouble to recommend 15,000 miles.
Also if you drive in sever condition, and I don't mean severe weather, but stop and go traffic or trips that are less than an hour long (like taking the kids to school or going grocery shopping), you might want to bump that oil change to 5000 miles to remove any water condensation that might be in the engine. Remove the oil cap and if you have any "Yellow Sludge" go with 5000 miles or less on the oil change intervals.
There are many devices and softwares on the market that will reset the oil light and inspection light. Just do a Google search for BMW inspection light reset or BMW oil light reset.
can't seem to find the official BMW checklist. S92-260
All i get is the other one: Bmw of north america, llc 2004 models (except x3 and x5 - use checklist sd92-260)
CURRENT
So got under the car and I see that part number on sticker for tranny fluid is:
83220024359
Pelican parts saying its replaced by:
83-22-0-397-114 which is dextron 6.
So is the ECS tuning package of d4 redline fluid ok? Should I get OEM fluid?
i have started editing the 1st post with part numbers and other info. anyone else with anything useful, chip in with your 2 cents!
CURRENT
Thanks for all this info.
Very useful!
Would the above-mentionned part numbers/info also apply for a 2008 3.0si X3?
I honestly do not know. Do you have m54 engine? I am trying to get all the info here from everyone, but as you can tell, there are only few visitors on this thread, which makes it hard to get info.
CURRENT
@ 82000 miles, i have changed Trans case fluid because of the "slipping feel" at the turns.
It was the exact issue, so the Trans case fluid should be changed every 60k miles at most before th issues arrise.
@ 83000 miles, i have replaced diff fluids, front and rear. 1.1 liters in rear, 0.7 liter in front. No issues before and no noticable difference after. The old fluid was little stinky, but still amber. i will keep the fluid changed each 60k miles though. RedLine 75w-90 was used.
@ 83000 miles i have replaced calipers, rotors, and pads. pads were on their way out. rotors could've been turned, but i didn't really feel like messing with the old ones. calipers came un-painted from the factory, so they weren't pretty, so i just got rebuilt ones and painted them up to prevent rust. Used Zimmerman rotors and Textar pads. Amazing combo! car stops on the dime now! Way better than stock!
@ 86000 miles, i have changed tranny filter, fluid. Used OEM filter kit, and OEM Dextron fluid. At least 5 quarts went in. Tranny was jerking once in a while before, not anymore. Old fluid was stinky and looked like mud water. Shifts very smooth now. Lifetime fluid - whatever... Although i am still not clear on the proceedure to properly level the transmition. the bottom of the pan is level when car is level to ground. But the transmission itself is level when the rear was lifted about 1 foot. So, if anyone can chime in, please do. For now i filled it with rear raised.
CURRENT
Thanks for this info! Very useful.
I've been debating whether I should change the tranny oil and filter. I'm just under 100K Miles and I feel the transmission <<kicks>> a bit. Not as smooth as it was.
The only thinkg that concerns me is that I do not have an infrared thermometer, so I'm concerned regarding the proper filling of the oil.
How much did the OEM parts cost? I found a kit on Bavauto that includes the filter, gasket, transmission pan bolts, and drain plug for 125$.
As for the oil, I'm surprised you only put in 5 quarts. I read that I have to put 8 liters... I know I have a 2008 and you have a 2004, but the difference still surprises me alot.
Not much more than 5 quarts came out, so I think I am safe. My tranny is Green label. I got filter kit from www.thebmwpartstore.com Since your car is 2008, I would check you part numbers. Get under car and get part number from tranny, then search realoem.com and find your filter kit part #.
CURRENT
Rear driver side regulator stopped working. I took it apart...
The little plastic clip broke, so I modified the window mount to get it fixed. Worked like s charm. Cost = $0.01 for the paperclip. See pics.
Sent from my SCH-I545 using Tapatalk 2
CURRENT
Replaced fuel filter. That was a big job! Hardest part is to take off the ring because it makes the whole plate spin also. I didnt have the right tool, so I rigged up the common tools to use as the wrench. Still had to put in quite a force. If you dont see how my tool would work, I suggest you have an expert to do this for you. At almost 90k miles, you can definitely feel the difference with new fuel filter. Tool is shown in the tightening up position. When you do tighten, use silicon on the threads of the ring.
Sent from mobile device
CURRENT
Replaced the door sensor which was intermittently faulting up...
Dealer quoted $640 for labor and parts.
They said the sensor will need to be "coded" and it takes 2 hours out of the 4.5 hours of labor.
I purchased part from the dealer online for about $60. Install took about 20 minutes.
No coding was necessary.
DEALER = RIP OFF!
http://www.youtube.com/watch?v=39TzTFzNgns
CURRENT
Hi, all... Just purchased a 2005 X3 to replace my Jeep... quite a step up. Will make a great fishing car!
It appears to be in great shape w/ 91,000 miles on the odo. Now the fun begins w/ fluid & filter replacements before winter sets in.
I enjoy doing all my own work on my '85 911 Porsche and my '70 VW Beetle.... guess I'll have to get used to this thing called a "radiator" ...
I have the Bentley manuals for the Porsche and the VW... damn shame they haven't come up with one for the X3, but I guess I can glean info from the 'net.
Milovanov: looks like you're into doing things yourself as well. The stealership isn't an option for me as the closest one is an hour and a half away. If I don't do it myself, I don't ride...
Question: when you replaced the fuel filter, I see you contrived a tool which I presume removes the plate at the top of the tank which, I suppose, holds a fuel sender/ maybe pump and filter combination. Care to go into a wee bit more detail on the process for me? Wouldn't mind changing the filter out as long as I'm having fun...
regards,
jlex.
i sed google search and read a lot before i started doing the job.
it is not an easy task, so read all up.
http://blog.bavauto.com/1520/bmw-x3-...r-replacement/
http://forums.bimmerforums.com/forum...er-Replacement
http://www.bimmerfest.com/forums/sho...d.php?t=458827
http://blog.bavauto.com/wp-content/u...regulator1.pdf
the important factor is when you remove the metal ring that holds the cover (the one with electric connector and fuel line),
make sure the cover itself does NOT spin, only the metal ring - otherwise you might damage the hoses connected to it.
Bimmerfest forum has a drawing of the assemblies. Pump is in the tank and filter is in the tank, all connected with wires and hoses to the top cover.
The filter also has a ground wire connected to it. whole job is done "blind" as you can't see because your arm will be on the way.
make sure when you connect new fuel filter, it is connected solid in the mount, shouldn't wiggle.
CURRENT
Thanks for the links.
I'll do fluid changes this weekend, then move on to the gas filter replacement later.
regards,
jlex.
Here is how not to go to dealer to buy rear windshield wiper - just buy in autozone and bend new wiper little. 14 inch size.
CURRENT
Hi everyone, got a 2004 X3 w a low 82000 KMs, I suppose that's about 50,000 Miles or so - just bought it and really enjoying it. However some weird behavior this weekend - vehicle was parked completely off, key out etc., and all of a sudden all 4 windows + sunroof opened completely. I have closed all and hasn't happened since - but I'm concerned and don't want to find puddles of water overnight if it decides to do again.
The other issue is my yellow engine light came on and I'm wondering if it just might need resetting - I just did the complete oil change with Mobil 1 0-40 full synthetic, and brake fluid flush (it was black), air and cabin air filters. The dashboard says next oil change in 13,000 kms - I need to reset that as it was just done. Could the yellow engine light just mean it's time (according to dealer) for an inspection? No record with dealer or vendor if Inspection II was ever done - is it really necessary to spend the $800+ just to have a 4 hour inspection? Don't want to get ripped off with "problems" they find and parts they mark up 400% haha.
Thanks for your help,
Daryl
