I don't have the hood release lever to open the hood on the kick panel like I have seen in photos. There is a button on the left lower side of the steering wheel at knee height, is that it? If so how does it work if the battery is dead? Is there an emergency mechanical pull system somewhere?
89' BMW 320is
71' BMW 2800cs
88' BMW 635csi
LOOK(this means get down on your knees) under the dash on the left side for the handle. ALL E24s have mechanical hood releases. The handle will be horizontal.( this means front to back.) sORRY- IT WILL BE VERTICAL IF THE HOOD IS LATCHED.
If you don't have that handle down by the kick panel, it's likely someone broke it off. The button has absolutely nothing to do with your hood. It is the power window circuit breaker.
C.R. Krieger #53302
Are you doubly sure the hood release is not there? The ones on the E9s are hand operated, whereas the E24 release levers are foot operated. Also, the E24 units are rather hidden in the closed position, so one can overlook them easily.
Bert
91 850i-A
1972 3.5 CSi (L-jet, Getrag 265 5 speed)
1988 ///M6
2021 X3 M40i
The back to back BIG COUPE duo
89' BMW 320is
71' BMW 2800cs
88' BMW 635csi
Actually hand to open and foot to close.
Bert
91 850i-A
1988 ///M6
2021 X3 M40i
Not really. it is a reach when you use your hand to stow it pushing it forward and up. There is a slight bend at the forward end for your finger to pull it down and mostly have to find it by feel. ...but no, you can't pull it down by your foot however if you are careful, you may be able to stow it back using your foot. A firm snap can be felt a lot better by you finger/hand to know it's locked.
'88 635, '92 325IC
Current: '94 MX-6 V6/5 '72 240Z '10 Mazda5
Past: '02 330i/5 '85 RX-7 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Wish list: Type 44 Manta Pre-'85 CGT 405 Mi16 SVX W123 Coupe
Huh, never gave a thought to using my foot to close the hood latch. Will ceases never wonder..........
dws
1970 Mercedes 280S
1973 Mercedes 450SLC
1979 Mercedes 450SLC
1981 Mercedes 380SL
1984 Mercedes 500SEC Euro
1995 Mercedes E320
1997 BMW 328i
It's the way I've been doing for 20 years now. Probably designed to operate when closing with either hand or foot. Foot method, use your left foot when seated. Just a natural push forward with foot, do it once, and see how natural and effortless it feels.
The release cable is probably one of the most robust component on an E24, still on my original and have never heard of one snapping either. On the other hand, the almost identical system used on the E9 does break fairly often.
Bert
91 850i-A
1988 ///M6
2021 X3 M40i
I happen to be changing my cable right now. I pulled the grommet off the end of the cable. The problem was the mechanisms got a little hard to operate so I pulled too hard on the handle and that was that.
Just be sure your locking mechanisms are operating freely and the cable will outlast you.
The hood release is in the same place even for right hand drive cars, it's bloody annoying to sit down and belt up only to realise you haven't locked down the hood and the lever is on the other side of the car.
It is above the foot rest. Turn towards the engine bay. You'll feel the tension as you squeeze it up.
