Ultimate e39 seat fix/disassembly/re-assembly (Lots-o-pictures)
So my wife's '99 540it had some issues with her driver's seat. The seam came apart and the foam was collapsing. I also had some aftermarket seat heaters that I was going to install. For some reason her car was fully loaded, except for cold weather. This is a comfort seat, sport seats are the same with the exception of the thigh bolster. It takes a little bit more work, but if you can do this you can figure it out.
I'm not going to tell you how to remove the seat, that should be covered in other places. If you can't get the seat out, this is beyond you.
So the worst part of this, is the first part. You need to take off the seatback.
There are clips on the back that snap in to the rail at the bottom. You pull the bottom clips out and it slides down.
The clips are down here:
They look like this (seatback removed)
Next you need to remove the side panels, if yours is broken this is a fine time to replace it.
There is 1 t30 in the front and one t30 hidden up by the seatback. there are also 3 rivets on the bottom of the trim holding the panel to the seatframe. Use a trim tool to pop them out and then remove the t30s.
Next you remove the seat bottom. You have to bend back a bunch of these little tabs to remove the leather from the frame. If you don't have enough room to get them off, compress the foam with your knee (kneel on the seat) or press on it some other way. (I like the kneel method)
before:
Tool and how-to bend
They're all around the bottom and around the sides of the seat. A longer section goes rearward (under the seatback) and goes to the bottom of the seat.
Once the leather is disconnected from the frame there are electrical connectors. Passenger has a seat mat detector and heater (if equipped), driver just has the possibility of the heater.
Pull the foam towards the front (if seat was sitting in car). Might have to work the foam over the rear bracket. You then have the seat leather/foam assembly.
Now, on BMWs the leather is held to the seat with "Hog rings" they require a special plier to install them and require a nice set of cutters to cut them out. My pliers were purchased through matco and came with a straight set and an angled set for about $40.
This is one installed
This is one cut out
the seat leather has rods in it that the rings go around, and the seat foam has molded in areas for the rings to go around.
This is the new foam pad ($170) and you can see the areas where the rings go
Here you can see the damaged foam and the stitches that came out. I re-stitched the seat here in preperation for re-install.
Here is a set heater installed on the passenger side. You're not suppose to install the heaters over the seatmat sensor and do so at your own risk.
The pleat in the middle was from hog ringing the heater to the seat foam .
Now you hog ring the seat leather back to the seat foam and re-assemble the seat. I bend the posts to hold the leather back to the seat with a small hammer.
At this point, if you were doing just a seat bottom you can re-assemble the seat and install it back into the car.
If you're doing heaters you need to pull the seat back. It's more of the same with the exception of you needing to remove the backrest from the lower seat frame. You pull out two t40s, they don't come out completely.
There is also this guy along the back of the seat that's horizontal. You compress the foam and unclip it.
Cut the hog rings, do what you need to and re-hog ring the seat. Put it back together and voala
These are the after pictures:
Always remember to bend the foam to the leather, not the opposite. The leather can tear relatively easy. The hardest part is going to be hog ringing. It takes a bit of practice and can be very frustrating but once you figure it out it's not bad. I think all and all the seat heaters cost $150 (both seats), foam bottom for the drivers seat was $170, pliers $40 and the rings weren't expensive. e39s use the "copper" rings if you get them from a dealer.
Dealers labor rate is 8 hours per seat to move/install both seat leathers.
I've done a lot of these seats and it takes me 1-2 hours. Your first one will take a LOT longer than that. (I'm guessing it's possible to take the full 8 hr)
e46 m3, some 740 sport shorts, F30h, LR3 and a 540it
