Results 1 to 9 of 9
Thread: Door Striker DIY
    Batavia, IL
    00 M Coupe, 08 335xi
    Door Striker DIY
    Took me a while to work out why the alarm was not working correctly. It would go off for no reason for a while and then finally would not arm at all.
    Thought it was the hood switch but that was OK. Finally noticed that the micro switch on the drivers door was worn and therefore not working when the door was closed.
    Ordered a new part ( 51 21 8 399 245) - Real OEM shows left and right parts, can't see what would be different but you never know!
    WARNING THE Plate that the Striker is bolted to is not attached to anything but the striker - Only remove one bolt at a time!!
    Step 1 - Disconnect the cable.
    Move the seat forward, remove the one screw holding the trim inside the door.
    I was able to pull the trim out enough to get at the connector and do the job without to much issue - It was still hooked in at the bottom.
    Disconnect the old cable and tie/tape a length of wire or string to the connector.
    Pop the rubber grommet into the door post.
    Step 2 - Remove the Striker.
    Remove the top bolt and use a stiff wire with a bend on the end or a longer bolt to keep the plate in place.
    Remove the lower bolt and ease the striker away from the panel and then replace the lower bolt.
    Remove the wire or top bolt and replace the original bolt and you end up with this
    Step 3 - Feed the new wire
    You can pull the old cable (with the extra wire/string attached) out of the door jamb. The rubber grommet is a bit of a squeeze but makes it through. I used a hook and screw driver combo on it.
    I did see another DIY where they did the opposite and cut the cable at the striker and pulled the wire backwards through the door jam.
    Either way you end up with the temporary wire that you can attache the new cable to and pull it back through.
    The new grommet was quiet a bit softer and was pulled through with no issue and popped into place on the inner bulkhead
    Step 4 - Bolt the new striker in place.
    Reverse of step 2.
    Remove the top bolt - put wire or longer bolt in place.
    Remove the bottom bolt. Put striker in place, replace bottom bolt.
    Remove wire/temp bolt and put original top bolt back.
    Tighten and adjust as required.
    Oct 2008
    NH
    2000 M Coupe
    Thanks for the DIY - added to my favorites.
    2000 Z3 MCoupe, '01 LSB E46 M3, '99 GTI VR6, '06 Audi A4, Andrew '95 Avus M3
    Sep 2012
    Santa Fe, NM
    2000 BMW Z3 Roadster
    This DIY is perfect! Just what I was looking for, as my driver's side door striker switch is bad. Thank you! Bought a replacement through my local BMW dealer then found out that Bavarian Autosports carries the same part for $10 less. Oh well; at least I didn't have to pay shipping.
    Thank you again,
    Hambone111
    Little Rock, AR
    98 Roadster 2.8L
    Thanks for this DIY... Both of my strikers need replacing and hadn't found a concise instructional yet :-)
    Mar 2013
    The Villages, Florida
    2002 325iT 2001 Z3
    Just replaced drivers door striker. Used 8mm-1.25x70 long bolt - works perfectly. However - I always thought my door should be closed a little more to make the body panels perfectly flush. So when I put the striker plate back I moved it in 1 possibly 2 mm - and the remote would not lock the doors - if I locked them with the key then the remote would open them but would not lock them again!! So I reset the striker plate to the original position and everything works perfectly.
    Jan 2015
    Daytona Beach, FL
    1997 BMW Z3 2.8
    Awesome write up! I just did mine, thanks to you it went well.
    Kent, Ohio
    1998 M Roadster
    Thanks for this write up--I'll be doing this job in the spring.
    Nov 2013
    St. Petersburg, FL
    E36/8 M Coupe, 911/997.2
    Subscribed and thanks! I've only needed to do this for about 5 years now...
    Could you imagine that striker backing plate falling down? What the heck would you do then!
    Ben
    '00 M Coupe (my daily for almost 10 glorious years now)
    '09 911 (wife's daily/my bucket list)
    '08 Z4 Coupe (wife's, sold, sometimes regrettably)
    '91 E34 M5 (gone, but not forgotten)
    '88 E30 (kid's)
    Oro Valley, AZ - USA
    see my signature
    Quote Originally Posted by Oilburnin View Post
    I think there's access holes from the inside, if you take off the interior trim pieces....this job is actually a lot less nerve racking if you do so. I've done them both ways.
    2006 R53 JCW (British Racing Green) - 1994 E31 840Ci 6spd (AVUS Blue)
    2021 F56 JCW (Rebel Green) - 2000 E38 740i Sport (Titanium Silver)
    2017 F26 X4 M40i (Carbon Black) - 2007 E91 328iT (Deep Green)
    2012 E82 135i M Sport (Marrakesh Brown) - 2015 E84 X1 (Cashmere Silver)
    2005 E53 X5 3.0i Sport (Kalahari Beige) - 2000 E36/7 M Roadster (Oxford Green)
    2000 E38 740i Sport (Oxford Green) - 1999 E36 M3 Coupe (Fern Green)
    1995 E31 840Ci Canadian (Oxford Green) - 2000 E36/8 M Coupe (Oxford Green)
    2004 E46 330Ci (Oxford Green) - 2001 E36/8 Z3 3.0i Coupe (Oxford Green)
    2002 E39 525i Sport (Oxford Green) - 2002 E36/7 M Roadster (Oxford Green)
    2001 E53 X5 3.0i Sport (Oxford Green) - 2007 E63 M6 (Silver Grey)
    1995 E31 840Ci (Oxford Green) - 2006 E86 M Coupe (Sepang Bronze)
    2001 E39 530i Sport (Aspen Silver) - 2009 E92 M3 (Space Grey)
    2001 E38 740i Sport (Sahara Beige) - 2008 E92 M3 (Melbourne Red)
    2000 E38 740i Sport Canadian (Sahara Beige) - 1997 E31 850Ci (Jet Black)
