can we have a adapater for puting 5x120 on my 325 ix 1989 (4x100) got some difficulty get some good wheel.
They make them. Just expensive.
What wheels are you finding for newer BMW's that you can't find for older ones? BMW is one of the only car makers that uses the 5x120 bolt pattern.
As for that actual adapters, Motorsport-Tech makes/sells custom ones. They will add some serious amounts of offset (or technically subtract I guess) to the overall fitment. But then again that might not be a bad thing since most e36 and e46 wheels are running a fairly high offset anyway, compared to e30 wheels (well, e30 M3 at least).
Metal Bumpers Are For BEEETCHES!!!!! "King of Lean" - Retired
"If that bikini isn't made of Micro-Fiber and has Quick Detailer on it then GTFO!" -BabyM
Yep, adapters is all I've heard about.... apart from the conversion.
Just wondering, is it possible to swap e30 m3 suspension onto an e30 325i without fabrication of any kind? (yes another noob question)
Past - 1989 BMW 325IS Bilstein/H&R Race | DSSR | 3.73 LSD | 191k | Rebuilt Motor SOLD
Daily - 1998 BMW M3/2/5 Imola Red | Bilstein/H&R | Dinan CAI/ Stage 2 Software | Supersprint Cat-Back
With all the parts? Yes.
Is it worth it? Considering how much you'll spend in just the parts for the swap BEFORE you get wheels/tires, probably not.
adapters r better..
that way u have the availability of being able to run 2 types of wheels.
a friend mine with a e28, has 5x120 to 5x114 adapters...
best choice he ever made
Not for your iX. Even the best adapters are going to increase your offset significantly. You my be able to manage that with the regular E30 which only has a medium offset. Then you'd end up with a high offset and could run the E36 wheels which are high offset. Since the iX already has a high offset, adapters would make it "extreme" and there aren't many wheels you could run. In fact I doubt there are any OE wheels at all.
"Howdy, Folks!"
Yes for the regular E30 but no for the iX. With the iX, rears will swap but the front is unique. To be honest, no one has yet come up with a 5 lug conversion for the iX that doesn't involve significant fabrication.
For the OP:
Really your wheel choices are-
OE iX weaves - 15x7 et41 These really are great wheels. You can't buy them new anymore. Only drawback is trying to keep them clean.
Any of the OE factory wheels for the regular E30. These sit farther outboard due to the lower offset, but they do fit. In fact, BMW lists the regular 15x7 et24 wheels as the replacement for the et41. You just have to replace them all. Even the 14" wheels fit.
There is a large selection of aftermarket wheels since the bolt pattern and offset is the same as many FWD cars. Generally they only require a hub-centric ring adapter.
"Howdy, Folks!"
Totally missed that the OP was sporting an iX. Wow, yeah, adapters will take you out too far in offset, as mentioned now. If you really need to go after different wheels, 4x100 to something that is common to FWD cars would be best. If you were trying to get it so you could swap wheels between the 740 and the iX, ain't gonna happen without some massive fender reworking on the e30.
ty for advice! because got 2x 325 ix mine and my father got one. but only one set of bbs 15 inch. i said to my father keep them im gonna found other wheel. Never do that :P dont wanna get some cheap aftermarket wheel. But is hard find bbs 15 inch + wheel for this car. Got spare set of 325 is not bad but its only 14 inch.
2011 M3 Sedan
2006 GMC Sierra 2500HD LBZ
1999 323i GTS2
1995 M3 - S50B32/S6S420G/3.91
1990 325is
1989 M3 - S54B32/GS6-37BZ
Hers: 1996 Porsche 911 Turbo
Hers: 1989 325iX
There is really nothing wrong with the 15x7 basket wheels that the IX has.
Jim Levie, Huntsville, AL
My ix came with a crappy set of 16in wheels that ive seen at big o tires. Theyre not real pretty but they get the job done, and are the right offset. Ill see if i cant get a picture tomorrow.
I have this conversion on my Cabrio... IMO the ultimate and coolest 5 lug conversion EVER
But as you have IX .. i am not sure how it will works,, maby an E36 compact bearing and hub will work,, because of the offset
But anyway.. here is some pictures of ,, oem E30 M3 5 lug
FRONT
REAR
ATTENTION.......... at the rear you DO NOT need to buy the complete trailing arms,, they are the same on 325 ((with ABS))
so just buy a bearing+ hub ((5x120 for E30 M3))
the best also imo is to buy E36 steering column.. then you will get a much better steering feel .. and i would consider buying THR ,, balljoint
Sveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
ULTIMA Evolution
Contacts
http://alpina.123.is/pictures/
The ix issue with a 5 lug isn't that it is an offset problem. It is dealing with front components that need to be able to xfer power to the wheels.
