Results 1 to 22 of 22
Thread: Brake bleeding with DIS DIY
    Chicago South IL
    2003 530i Sport
    So i left my system open for a week with brake calipers removed and I forgot to pour fluid back into reservoir
    When i came back after a week main reservoir was empty
    ( I know my bad , but i am doing it for the first time )
    Now i installed new rotors, pads, rebuild calipers and bled the system with compressor under 15 psi ( CNN method )
    All went smooth , no air bubbles but my pedal is soft and i have excessive brake pedal travel
    I believe this is because reservoir was empty and i probably got air into the system
    I am reading this thread with a lot of good info
    http://forum.roadfly.com/threads/131...1#post13121466
    Tomorrow i will try to re-bleed my system +ABS with help of BMW software ( DIS )
    http://tis.spaghetticoder.org/s/view.pl?1/01/48/47
    Here we go with GT1 BLEEDING
    The bleeding is under service function => DCS 5.7 => Control module / hydraulics => bleeding, DCS hydraulics
    I was searching this info around 1H , was really not easy to find where this option is
    finally
    Next you go to test plan and read 1-8 how to proceed
    Basically 1-5 explained by CNN as a one man bleeding
    1-man Hydraulic Bleeding Kit for those with Air Compressor!
    So I used euro ATE Euro Cap for the air compressor which come with a Black Label Aluminum European Power Bleeder ( i didnt use it , only the perfect aluminum cap )
    Now top fluid to MAX mark in reservoir , install ATE Euro Cap on the top of reservoir and connect it to air compressor using the quick disconnect
    Keep air compressor UNDER 15 PSI ( TIS said less than 2 bar )
    Now attach empty bottle to the small connector on RR caliper , release it and start to bleed with GT1 in the following order
    1. Start bleeding , - it will push fluid down to the empty bottle
    2. Activate pressupply pump , - this will activate pump ( more fluid )
    3. Press pedal 5 times as far it is will go
    Top more fluid and repeat for the LR, then RF and then LF, every time add more fluid
    Now i dont have any single buble in my system but still my pedal is soft
    In the end i think this is new Akebano pads problem , looks like they are total CRAP , i am going to send them back and buy some quality pads
    Be ready it will be a real PITA if you do it for the first time alone
    Stay tuned
    Sep 2010
    england
    1998 bmw m3 coupe smg
    nice one cheers,i could not find this option in dis for my car but inpa had it.trouble is there was no instructions like dis.
    Chicago South IL
    2003 530i Sport
    yaa
    Bleeding with GT1 was always the question for me and i never got an answer how to do it right
    Hope we will have more people to respond
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Igor,
    Interesting thread...!
    Just for me to understand...
    You are using your laptop computer with this "Gt-1" program hooked-up to your car to run through these procedures, correct?
    If you are looking for low dust pads that offer great bite, I would look at the Stop Tech pads...!
    I really like them...
    My previous pads were OEM.
    So, going from OEM pads, directly to these Stop Tech pads, I felt that the Stop Tech pads offered a little more bite, but are more "linear" than the OEM pads.
    The low amount of dust just happened to be a bonus...
    I too recently bled my brakes.
    I used the Motive Black Label bleeder, with the same Cnc'd red reservoir cap.
    I did not fill the bleeder with any brake fluid.
    I just used the bleeder to add pressure to the system, and added new fluid to the reservoir after I sucked out as much of the bad/ old fluid from the reservoir as possible.
    Thanks!
    Jason
    Chicago South IL
    2003 530i Sport
    Hey Jason
    a) Yes i am using GT1 ( DIS )
    b) pads :
    Akebono Ultra pads are junk
    In the end i think my problem was just a new Akebono pads
    Many reported the same soft pedal issue with them and I am going to return them back to RockAuto
    read THIS
    http://www.m5board.com/vbulletin/e39...ds-review.html
    here is my problem :
    Well a week become a day. I drove the car this morning and the brakes were making me crazy.
    I picked up a set of Wagner ThermoQuite - basically premium OE style pads and removed the Akebono's.
    The difference was apparent by the end of my driveway .The pedal feel is back to normal and the Akebono's are being returned.
    But I glad i found the way how to bleed the system with GT1
    c) this :
    but instead of using Motive Black Label bleeder i used ( Euro Cap + compressor as CNN ) combination
    USA
    (OO=[][]=OO)
    I am not crazy for wanting to periodically bleed the ABS under normal operation, am I?
    Sep 2010
    england
    well its a sealed system so once the air is out,its out.
    Alexandria, VA
    Yes
    FWIW, i've been perfectly happy with Akebono Euro pads. i haven't resorted to bleeding using the service functions, but sounds like you did it right. this does activate the ABS pump, correct?
    James
    '88 M3 (track and weekends) | '01 540i/6 (daily) | '95 4Runner (lifted and armored)
    Sep 2010
    england
    stupid question but did you do the "pump pedal 5 times" with the bleed nipple still open?
    Chicago South IL
    2003 530i Sport
    Quote Originally Posted by joako View Post
    why one should "periodically" bleed system which dont have any issue ?
    Quote Originally Posted by jht3 View Post
    Akebono Ultra is a total junk as well as Rockauto return service
    I RE-installed my old Jurid and my brakes came back again
    Quote Originally Posted by jamie123 View Post
    I believe this is the idea to pump pedal 5 times with an open bleed nipple to push all bubbles out
    What is the point to pump pedal on a close system ?
    Last edited by champaign777; 08-24-2012 at 11:45 AM. Reason: Automerged Doublepost
    Nov 2005
    SL,UT
    E39, E38s, e46, lr3
    It's not necessary to pump the brake pedal.
    As long as you don't have the precharge pump out or the master cylinder, DIS activation isn't necessary.
    I can get a master cylinder to bleed 50% of the time without it, pre-charge pump always needs it.
    PS, use this guy:
    http://www.northerntool.com/shop/too...ci_kw={keyword}
    You fill it full of brake fluid, pump it up and hook it up to the master cylinder with an adaptor (have to get it seperately)
    That way you don't have to keep topping off the master cylinder with the air compressor.
    e46 m3, some 740 sport shorts, F30h, LR3 and a 540it
    Chicago South IL
    2003 530i Sport
    Aradaiel , there are many ways to bleed brakes but the way you mentioned is not the best one
    This maybe faster but not as clean as using "compressor method"
    This is because using "compressor method" you don't have any brake fluid to clean after this job
    And if you want reuse bleeder after 1-2 years it will be dirty from the old fluid
    I personally like CNN compressor method even it might take more time
    Last edited by champaign777; 07-05-2012 at 05:49 PM. Reason: Automerged Doublepost
    Sep 2010
    england
    Quote Originally Posted by champaign777 View Post
    well when you put it like that the answer is obvious,i thought you were supposed to shut the nipple off on the upstroke of the pedal?
    Chicago South IL
    2003 530i Sport
    no worry
    we all learn
    also as mentioned in step 7
    press brake pedal 5 times down as far as it will go
    the brake fluid that escapes must be free of bubbles
    Nov 2005
    SL,UT
    E39, E38s, e46, lr3
    You have your method, I have mine.
    I make a living with my method and I have no fluid to clean afterwards.
    I'm not here to get into a penis waving contest but my way is easier, works as well and is much easier. It also works if you're bleeding DSC with DIS.
    Take it for what it's worth.
    Cowtown -The Great NW
    2003 530iA
    I have the Motive with the Euro cap, and it's pretty much the same as the Northerntool, only 1/2 price. Works excellent. Same cap assy Igor is using. the benefit is one can purchase or fabricate different adapters for different cars at a fraction of price.
    However, the method I use is close to CNN's method, aka I don't fill the cylinder with brake fluid to avoid the mess, just fill the reservoir and monitor. Same as Cam's method, only one does not have to use a long hose or handle a big compressor unit.
    This method is more expensive than Cam's, is the same principle, only lighter duty.
    Looking for a DIY? Parts? Check this out, it might be your ticket
    Stable: e92is, e53 N62, e46M54B25, Tribby & e39 M54B30 R.I.P.
    Apr 2009
    United Kingdom
    BMW 318ci M-Sport
    I just went through this routine recently.
    Prerequisite:
    - Motive bleeder or equivalent and able to go up to 29psi as per BMW spec.
    - Fluid collector and tube to be connected to bleeding nipples.
    1. Pressurise to 29psi.
    2. Look for 'Ventilation' in Service Functions - DSC and follow the instructions. It will ask if it's a fluid chance, bleeding, unit replacement etc. and then prompt you to go to each wheel, starting with rear right.
    Sequence is as follows:
    - insert tube from collecting jar
    - release bleeder screw until you see a reasonable flow (you won't have a mighty fast flow like manual bleeding)
    - click to acknowledge in DIS
    - hear pump activating and wait for the 2 cycles to end
    - pump the pedal 5 times (bleeder screw still open)
    - close bleeder screw
    - go to next wheel indicated by DIS
    ... and so on.
    It's very important to pump the pedal as per instructions otherwise it's very possible you will still have air trapped in the system.
    EDIT:
    I won't advise pressurizing the reservoir directly as the op suggested, you're really asking for trouble. Air puts a lot more strain on the reservoir walls as the fluid goes down, to the point where you see the joints whitening. That to me is a sign that you're getting close to popping it.
    Also, for a thorough fluid change you have to stop every time fluid goes down to add more fluid, and that's a lot of times.
    Dec 2007
    Anaheim, CA
    2002 M3 Cabrio
    Quote Originally Posted by lestat View Post
    pump and hold on the 5th time?
    Apr 2009
    United Kingdom
    BMW 318ci M-Sport
    Quote Originally Posted by casper3t View Post
    no holding, just pumping.
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    - hear pump activating and wait for the 2 cycles to end.
    BUMP
    Does anyone know how long each of the pump activation cycles are?
    I'm attempting to do this procedure on my E36 by manually activating the ABS pump (jumping positions 30 & 87 on the ASC relay) and I need to know ho long to let the ABS pump cycle.
    This is a modified system with a hydroboost and a master cylinder from a 2004 Mustang. I've already pressure bled the system several times but the pedal still goes to the floor.
    TIA.
    Tipsy
    Jul 2004
    Houston, TX
    36 Cylinders
    I answered the actual answer in your other thread. And the DSC system is very different than your ASC E36 system.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jul 2013
    FL Gulf Coast
    Replying to that now.
    Thanks.
    Tipsy
