The below part is pretty much just lying loose in the engine bay. Kind of flopping around on the passenger wheel well. It is plugged in, but it would seem to me that it attaches to something? Maybe vacuum lines?
I thought it could be the electric valve but it doesn't seem so.
I tried running the numbers on the part through google, and realoem and no luck.
Any idea what part it is, and what does it do?
1998 Garageworks' E39 Widebody - needs a lot of work, but I'm bringing it back.
Blinker fluid filter.
Lolz,Originally Posted by gjVah
Thats your hood position switch, it's mounted on the driver side cabin filter. Pretty useless part. Mine is unplugged most of the time due to a broken clip.
My CCV Delete Mod : http://www.bimmerforums.com/forum/sh...em-(Pic-Heavy)
Thats the altitude pressure sensor. I saw it too on an E39 in the junkyard, then went on RealOEM to find out what it is. Havent really searched for what it does, but apparently its for the EFI system, probably helps the DME correct fueling for the altitude the car is in.
