My a/c has been blowing hot yet the compressor is coming on. I know from this forum that the compressor will come on if the R134 is low. I added a 18oz can and a 12oz can and it is still blowing hot. Why is it still blowing hot after all of this R134 I added and the compressor is still coming on?
It sounds like you're going to need the tool that tells you pressure differential between high and low sides. This will tell you if the compressor is operating correctly, and it will tell you if charge is correct.
Also, the charge does not have to be off by much, even with an otherwise correctly operating system, in order to get results other than the one you want.
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
Blindly adding freon without actually checking the operation of the system only works if it was working a short time before. Ie; you must have some reason to believe that a leak is the problem, and the system cannot be completely empty.
If you only added 30oz, that's still about only half full if the system was completely empty to start with.
Unless you have the knowledge and equipment to work on ac system, you are better off taking the car to a shop that specialize in ac repairs.
Obviously you have a leak if the system if you can put 30 oz. of refrigerant into the system. Putting refrigerant into a system that is leaking out the refrigerant doesn't do you any good or the people that inhabit this planet or will inhabit this planets in the years to come.
Does anyone know what the high and low pressure setting should be? I converted my R12 to R134. Would the settings be different? Does the system hold the same amount of freon if it was R12 or R134?
I have the exact problem. I am testing the pressures this week http://www.ackits.com/aacf/ptchart.cfm. I dont know if it is going to be the a/c compressor or system being clogged.
I took mine in after replcing the compressor to get the old school freon. I charged the A/C but no cold air. I was told there is a stuck valve somewhere in the interior of the car behind the glove box or something and its a real hassle
Thanks for all the replies, I have a/c gauges and I test the system. The low side is incredible high and the low side is about 100.
If the compressor is turning on and off like it's supposed to, you've got pressure, and you're still getting heat, look into your heater control valves being stuck open.
Was the compressor engaged when you took the reading? Compressor has to be running in order for the low side pressure to be below the system pressure. With the compressor running, the low side pressure should be between 40 and 45 psi depending on the ambient temperature.
The e34 holds over 3.00lbs ... great thread revival with incorrect knowledge though... hahahahaha
Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
G/F’s E34 92/ 525iT + F48 18/ X1
