Results 1 to 10 of 10
Thread: Best way to remove foam from under hood and trunk?
    SD, Cali, USA
    1995 M3, 1985 745i , S13 240sx sr20det
    He foam Underhoid and under rear parcel has rotted off. Pretty much just sheets of sticky tape left. I don't see any easy way to remove it, any ideas?
    95 BMW M3 Alpine-
    <GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
    Herriman UT
    81 323i 86 535i 08 335i
    Dry ice or heat gun.
    80 B6, 81 & 82 323, 85 745i, 86 535i-all euro. 01 750iL Blk/Blk 08 335i
    SD, Cali, USA
    I don't know if it's solid enough and a heat gun might turn it to glue. Heat gun seems like best bet though, then clean ip residue.
    95 BMW M3 Alpine-
    SD, Cali, USA
    First attempt and all the foam came off easy, but the sticky stayed behind. Tried every thing I could think of including PB blaster which usually works good for sticky. Part of my problem is there was a power steering leak that caked onto the hood. Maybe some kind of steam gun is what I'm thinking next.
    95 BMW M3 Alpine-
    Aug 2011
    Halifax
    1987 BMW 735i
    I went through this last year, spent about an hour with a jug of acetone. Melted it right off with the help of a plastic putty knife. Take proper precautions with the fumes though.
    You can get the acetone at any hardware store and it works great, the clear coat can resist some pretty harsh chemicals just use it sparingly and wear some heavy duty rubber gloves.
    SD, Cali, USA
    I'll give that a shot then
    95 BMW M3 Alpine-
    Aug 2011
    Halifax
    1987 BMW 735i
    Yeah the acetone is good as well because it just evaporates and doesn't leave any oil, so when you peel the backing off the new ones you bought it will stick right on and give a good bond.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Removal is a bitch, never thought of acetone... boy does that stuff smell awful.
    Anyway, for reapply... use 3M Super Trim Adhesive. I have installed countless MB hood pads with that stuff. Maybe they have a good remover? I have never looked.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Billings, MT
    2013 328i xDrive
    Not sure I would use a highly flammable chemical for such an application...
    Do you have an air compressor? A good eraser wheel will take it right off.
    -Chris
    My e30 build thread/color change here
    Feb 2012
    Norway
    535i, 730i, 732i.
    I used a pressure washer
