Wiring O.E. Power Antenna to Work with Single-Wire Radio
I have acquired an O.E. two-wire BMW power antenna for my '84 320i. As some P.O. "thoguhtfully" hacked my radio harness, it is easier for the moment to retain the aftermarket Kenwood head unit which is currently in the car than to install an O.E radio.
Problem: the Kenwood has only one power antenna wire. How do I reconcile this with the dual wires used by the antenna? The white lead is for "up" and the red lead is for "down".
I know that I can't be the first one to ask this question, but I can find no definitive answer by searching this forum.
Since I realize that some will wonder why I caused this problem for myself by acquiring and installing the the power antenna, it was to keep the trunk dry (aftermarket antenna was leaking) and so that I can put a custom-fit cover over the car without having to make a hole in it.
Jeff
1984 320i Baur TC2 5-Speed Opalgrün (Jeff's)
1987 325e Sedan A/T Zinnoberrot (Dawn's)
1984 633 CSi 5-speed Bronzit (Ours . . . if she says so)
