Looking to replace my JC60 ITG foam filter that comes with the Jim Conforti cold air intake. The lowest price I could find is about $80 or more with shipping and I know the foam filter probably does a better job of cleaning the engine's air with the trifoam technology. Has anyone found an alternative filter that resembles the ITG filter in size, that provides close performance, and is somewhat reasonably priced? Any experience of the filter replacement on the JC product would be helpful, thanks.
Dude I had the same filter, after the ITG filter deteriorated into pieces I just bought a Spectre Cone Air Filter $25.00 from the local auto part store its been on my intake for 4+years without issuse I clean it and hose it down every now and then
$80.00 for the ITG its just crazy
Good luck with your choice
Yea I wouldn't go with the ITG again, I went with an AEM Dryflow I scored for about 37, I would never touch the ITG again
I've never had an issue with my ITG filter. It's still intact and washes out fine. What other issues are their with them?
ProjectTechnik.com - Alberta based BMW Community
| OE M3 Bumper | M3 Mirrors | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Founding Member of the Canyonrot Club #343!
Kool blue filter I love it.. 15$ and really the only thing actually filtering is the oil, I use k&n oil.
I have the Conforti (not hooked up at the moment) with the ITG. My first filter decomposed after only a few washes. The decomposition was supposedly related to the NoToil cleaning solution (either a compatibility thing and/or mixing the solution too strong). My understanding is the filters are fine if you're careful with the cleanerI like the ITG, but I won't be using the NoToil stuff again at all.
My first ITG filter was destroyed during the first wash with No-Toil cleaner. The second filter lasted only two washes with a different cleaner. After that I gave up on foam filters and replaced it with an aFe cone filter. It was half the cost of the ITG and should last longer.
Stock airbox with debaffle FTW. $10 filter every 10,000 miles, and I can probably go longer than that![]()
Did the 21-203BF filter base overlap the carbon fiber intake pipe when you installed it?
I run an amsoil filter.
