Description:
One set of 4 18x8.5/9.5 LM style wheels
WHEEL SPECIFICATIONS
Offset: 35mm
Weight: ~24lbs
Hub size: 72.6mm
Bolt Pattern: 5x120
Finish: Silver Polished Lip
Shipping: $85
Price: $589
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards. Obvious exclusion is curbing, denting or any other misuse that can damage or etch the finish such as use of strong chemicals in the cleaning process.
Manufacturing Defect Warranty: The wheels are made utilizing the low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrating or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements. So we focused on putting the synergies in place that allows us to offer that service.
You can always call us at 248 686 2035 if you have any questions.
PURCHASING
You are welcome to purchase the wheels from our website at www.eurowheelspro.com or you can call your order in at 248 686 2035 or we can send you a paypal invoice.
Thanks for looking!
Vassili,
EuroWheels Pro
248 468 4683
<b> CLICK LOGO FOR WEBSITE</b>
<a href="http://www.eurowheelspro.com"><img src="http://www.eurowheelspro.com/shop/images/EWP_Logo.gif" border="0"></a>
i want a set but will wait
No worries, we are planning to have them in stock moving forward
Vassili,
EuroWheels Pro
248 468 4683
Is it possible to get a set of all 8.5''? I'm pretty sure I'd need to roll my fenders to fit 9.5 on a 97 328is
Would definitely want a square set-up. really nice looking wheel
Are wheels JWL and TUV approved?
Where are the wheels made (country)?
Re: 18x8.5 all around: Ask and you shall receive ;-)
Please check our website.
We only have a couple of sets of these left, we will be getting them in again in late March.
The wheels are made at an OEM factory that has production with VW, Honda and Mercedes. Our factory uses low pressure casting process, similar to OEM wheels. Among other quality tests, the wheels go through 100% x-ray inspection to ensure there are no micro cracks and also 100% balancing test.
Finally the wheels come with an unmatched 2 year warranty on the finish and also a 100% fitment warranty.
Since we are the importers, we eliminate all middlemen and we are able to pass all the savings to our customers, hence the awesome price.
In a few days you might see them on customer cars if other members post pictures of them, as we have exclusively made them available to bimmerforums and these have been popular.
Let me know if I can help in any other way,
Vassili
248 686 2035
Oh, to your question, yes, they exceed all international quality standards, JWL, VIA and on some molds TUV.
Thanks!
Last edited by EuroWheels Pro; 02-17-2012 at 12:25 AM. Reason: Automerged Doublepost
Vassili,
EuroWheels Pro
248 468 4683
The factory is in China and the wheels are made there, just like the wheels made on many GM, Honda, Mercedes, Toyota cars available all over the world as well as many aftermarket wheel producers. including some big names that sell wheels at a premium also on this forum. (I spoke with the factory manager myself).
Regarding the raw material, aluminum is a globally traded commodity. There are many countries that manufacture it for commercial use and China is a big customer as they buy a lot of it.
Bottom line, we are so confident of the quality of the products we sell, we can provide a warranty that no one else matches, to my knowledge. If your wheels do not fit on your car, we will not only refund you the cost of the wheels, but we will also refund you the money spent on shipping both ways.
Hope that helps,
Vassili
Vassili,
EuroWheels Pro
248 468 4683
What a stickler! ^^^
Thanks for responding to the questions posted. You return policy is above and beyond what most vendors offer and you should advertise it on your website. The return policy should be updated to reflect that: http://www.eurowheelspro.com/shop/sh...1a8cfe3fc84dc8
SNIP>It is the buyer's responsibility to ensure that the wheels are the correct size and that they will fit the vehicle. We do our best to research the fitment applications which are posted above for your convenience, so please use that to verify the wheels will fit your car.
If, however, the buyer decides to return wheels otherwise free of any defects or damage, the wheels must be postmarked within 14 days from receipt. A 20% restocking fee will be charged to the order. Finally, the buyer bears full responsibility for shipping charges back to us.
do they come in gold? any tire packages for the setup shown?
mickeylex thank you, we always try to stay on the conservative side when it comes to quoting return policy.
The policy you posted refers to people that will pull the trigger on a set without doing the proper investigation to see if they will fit their car and they also do not check with us to help them. In that case, this is meant to protect ourselves from them trying to get us to pay for the shipping charges.
We will in fact go out of our way, and we have done so in the past to protect and support our customers from issues they encounter after they get their wheels from us after we have talked. We consider that our responsibility, which is why we guaranty fitment once we have confirmed that the wheels should fit ones car.
cruzd2, unfortunately they don't come in gold.
We are going to be getting them in gold in the 5x100 bolt pattern 35mm in a few weeks. You could use bolt pattern adapters if you wanted to. Or you could refinish these.
Thanks,
Vassili,
EuroWheels Pro
248 468 4683
great wheels i loved my set
WTB used e36 m3 coilovers! FS billy sport/tein race. ACS type 3 fs/ds2's fs
SR20Fastback We will also offer the package with the wheels & 4 10mm hubcentric spacers which is what it would take to fit on your car for only $20 more.
brandon11130 that is awesome! This thread needs some pics!
Vassili,
EuroWheels Pro
248 468 4683
always wanted a set of these. do they come with the bbs caps? i will await pictures.
Staggered 17" available ?
