https://rapidshare.com/files/2737587...6_b.part01.rar
https://rapidshare.com/files/1649447...6_b.part02.rar
https://rapidshare.com/files/7410741...6_b.part03.rar
https://rapidshare.com/files/2490768...6_b.part04.rar
https://rapidshare.com/files/4182173...6_b.part07.rar
https://rapidshare.com/files/1651745...6_b.part08.rar
https://rapidshare.com/files/3232053...6_b.part09.rar
https://rapidshare.com/files/3375658...6_b.part10.rar
https://rapidshare.com/files/5248384...6_b.part05.rar
https://rapidshare.com/files/3614727...6_b.part06.rar
https://rapidshare.com/files/4077299...6_b.part11.rar
ICOM emulator to follow when I have it. Please be aware this VMware install requires a dual core CPU.
Hi Blood thanks how much memory needed for this machine? and what type of interface needed?
Any advantage to this over DIS for those of us w/ earlier cars?
At minimum required:
For ISTA/D VM - Core 2 Duo/4Gb RAM/50Gb disk space
Optimal:
Core i5/8Gb RAM/Win x64/100Gb disk space on 7200RPM disk or SSD
Not only wiring diagrams and diagnosis, but also repair and replace, training, and other documents. This is essentially DIS,WDS,TIS,etc. all combined in the third generation of tools. This is not progamming, and I would not do programming on newer cars with the ICOM emulator and the ISSS VM (should you have it).
Is this the hacked offline mode VM from darksys?
Installed and working on Macbook Pro early 2011 - 8gb RAM and Imac mid 2011 8gb ram, working ok, but... Is any way to install ISTA-P in this vmware? or any vmware image for ISTA-P? I'm thinking in buying a Icom clone to try (it's for personal use, not professional).
WBR!!!!
Hi BLooD30,
Below link is not found, could you pls upload ?
Thank.
I have real ICOM, this VM do not recognise icom. have you admin password for this install. TKS. in advance.
Hi, this is only ISTA/D or ISIS+ISTA/D??
If it is ISIS+ISTA/D, how I can install ISTA/P with the DVD's on the same VMWare image??
Thank you in advance
Regards
Any chance to reupload the software ...? Maybe another member ?
TNX
Hi I have it but I need ISTA/P installed on VMWare or instruction to add it on ISID VMWare image!!
Could someone help me??
You need an ISSS system that has connected at least once to valid IBASE server. Then you can take it offline and edit one of the XML files to make it offline. The ISID VM attached here has only diagnosis (ISTA-D). ISTA-P shows greyed out since the the ISID is in offline mode. Invoking ISTA-P needs a valid ISSS to call.
Sorry cegeste, could you explain me better what you want mean and what I must do to have the ISTA/P?? I have the ISTA/P 2.41 version files (Dvd)
Regards
Much easier to get and does not expire.
