DIY: Timing Case Cover Gaskets (Upper and Lower), Timing Chain Guides, Timing Chain Tensioner, Thermostat.
I decided to finally tackle an intermittent oil leak. From what I could tell this leak was coming from the lower timing case cover gasket. I never found the leak specifically as the lower front half of my engine is just a thick mess of oil, dirt and road grime. The leak definitely is not coming from the oil filter housing - that area is dry and I have already fixed a leak there. It was coming from the passenger side (LHD), near the AC compressor.
Parts (M44 Engine):
Gaskets
• Full Timing Case Cover Gasket Set: 11141432099
• Profile Gasket (between upper and lower covers): 11141247837
• Thermostat Gasket (in lieu of thermostat replacement): 11531743179
• Front "Main" Seal: 11141439570
• Timing Chain Tensioner Gasket: 07119963355
• Valve Cover Gasket: 11121721876
• Spark Plug Tube Gasket (3x): 11121721476
• Spark Plug Tube Gasket (1x): 11121721475
• Oil Squirter Seal: 11121247948
Timing Chain Guides / Tensioner
• Timing Chain Tensioner: 11311743187
• Timing Chain Tensioner Guide (Right Side of Engine): 11311743262
• Full Guide Rail (Left Side of Engine): 11311247470
• Deflection Guide (Lower Right Side of engine): 11311739130
• Top Guide: 11311743046
• Bottom Guide: 11311734694
Misc.
Main Crank Bolt: 11211721100
Here's what I was dealing with : It was leaving numerous oil spots on the ground. A few times over the past year it left quite a large amount of oil - literally a small puddle.
• To start, you need to follow the instructions in the valve cover gasket DIY thread. The valve cover needs to come off.
http://318ti.org/forum/showthread.php?t=12007
• Remover the intake snorkel, snorkel "rest" and cooling fan. This will give you a lot more access to the front of the engine.
• Drain the coolant. Remove the thermostat and two main radiator hoses.
• Remove the two engine belts. Remove the A/C belt tensioner.
• Remove the water pump pulley. Four bolts.
• Unbolt the cam postion sensor.
• The upper timing case cover can now be removed. With both the upper and lower timing case covers, make sure you keep track of which bolt goes where as there are different size/length bolts involved.
• Now the AC compressor bracket needs to be loosened. There are five bolts holding the bracket to the engine. Two on the front of the lower timing case and three that need to be accessed from under the car. Unfortunately one of those bolts is blocked by the compressor itself. So you need to remove the 3 bolts (allen head) that hold the compressor to the bracket. That allows the compressor to move enough to access one of the bracket bolts.
• Remove the A/C belt pulley off the front of the vibration dampener. Three bolts
• Now comes time to remove that main vibration dampener/crankshaft bolt. It's a M16x120mm; 12.9 bolt - huge. You need a 22mm socket and either an impact gun or a very large breaker bar. in addition, you will need to hold the crankshaft in place as it will obviously just rotate as you attempt to turn the bolt. From what I understand you can "pin" the flywheel through the flywheel locking hole (the one used to lock the engine at TDC during the timing procedure). I decided to use the tool made for the job. It consists of a large holder bar (SIR Tools 3034-2 or BMW Tool "11 2 150") , a spacer piece (BMW Tool #11 2 410 - BMW part #83300490884) and three bolts (that I bought). I bought M8x60mm; 12.9 bolts, but they turned out to be too long so I had to add the nuts in the photos as a spacer. M8x50mm should be ideal.
The tool.
• Bolt the holding tool in place and position the arm downward. I set it up so the force of the tool pushes down on my floor jack which worked perfectly.
• I tried to remove the bolt with my little impact gun but it couldn't do it. What I think it did though is loosen it a tad as when I switched to my long ratchet and a 3' pipe, I barely had to give it any force and it loosened right up! Getting this bolt loose was my number one concern with this project.
Love this compact little impact gun (Klutch, from Northern Tool), but it's a little weak for something this big.
3' pipe.
Close-ups.
• Now we have full access to remove the lower timing case cover. The A/C compressor bracket is still attached in this photo.
• Engine shots
• You can now replace the timing case cover gaskets, but I will also dig further in at this point and replace the timing chain guides and chain tensioner. I haven't heard of many issues with timing chain guides on the M42 or M44, but after 15+ years and 210,000 miles, how good can plastic internal engine parts be??
• To remove the guides you will need to remove the timing chain and its sprockets. The instructions are in the Bentely manual, and you will also need the timing tools which are a cam locking jig and a flywheel TDC pin.
• Once the engine is locked, you can remove the chain tensioner.
• Now remove the cam sprocket bolts. I suggest zip tying the chain to the cam sprockets and also not letting the chain "skip a tooth" at the crankshaft sprocket as you remove it. Keeping the chain and sprockets matched simplifies the installation.
Here's the chain and sprockets removed as one unit.
And the engine without its chain.
• Now comes time to remove the chain guides. It's a very simple, just unbolt and reinstall. No special tricks upon installation other that the top bolt on the driver's side (LHD) rail has weird sleeve. Instructions for that one are on page 117-4 of the Bentley manual. I also suggest a coating of grease on the sliding surface for the initial engine start up.
The engine minus the chain and guides.
Here's what happened to the lower guide upon removal. The rotation force of just removing the little bolt was enough to snap it.
Wear on the old guides vs. the new ones.
• After the guides and chain are reinstalled, the new chain tensioner can be installed. There was a note with my new tensioner saying to run the engine at 3,500 RPM for 20 seconds immediately upon first start up. I'm assuming this is to build oil pressure up on the tensioner right away.
• Please follow the proper timing procedures listed in the BMW TIS or Bentley! Triple check your timing before you button it back up!
• I installed the new gaskets using Hylomar Universal Blue gasket sealer, until I ran out. I then used Permatex No. 2 Gasket Sealer which is a similar type product.
To hold the gaskets in the place I made these little tools (which I think is also a BMW "special tool"). Just long, M6 bolts with the heads cut off.
• In addition, install a new front oil radial seal. You need to forcefully pry the old one out and carefull tap in the new one. These are difficult seals to set, just like rear main seals. I suggest generously oiling/greasing the seal's lip and well as the vibration dampener surface which it contacts.
• Once the lower timing cover is in place you can reinstall the vibration dampener. Using the crank holding tool again, torque a NEW main bolt to 244 ft.-lbs. I needed to borrow a torque wrench from AutoZone that went up to 250 ft.-lbs., mine only goes to 150.
That's about it - just work backwards from there, following the tips on the Bentley manual, chapter 117. While my car didn't need it, I decided to replace the valve cover gasket, spark plug tube seals, oil seal for the cam sprayer and the thermostat.
Nice DIY I was always curious how to get that damn crank pully off as I have to swap mine for one that was made for A/C.
Wow that looks pretty involved. My M42 engine has been leaking oil from that general area for a while now. It's about a quart every 2 months, so it's not bad enough for me to get it fixed, but enough to be annoying and leave spots.
Great write-up, I vote for this to be added to the DIY section.
We did this with my friends Pontiac, it was considerably easier on that engine though, just need to take the motor mount off and voila. We messed up the timing tho.. Took us like 3 weeks to figure out what was up, great DIY though!
Thanks for the great write-up! Sorry for waking up the sleeping thread guys! Don't you have to drain the oil for this task?
This is essentially the same procedure as the cover on my m52. You don't need to drain the oil
