Looking to see what guys are using for replacement radiators. I believe the S54 radiator is 3 row and the S52 is a 2 row.
Does anyone know if the larger will fit in a S52?
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
not exactly.
the one your looking for is the one from a Z3M, a late one with the s54 in it.
I've heard of many using the S54 radiator in their E36 M3, I will probably get one to replace my stock one currently at 160k miles
Z3M S54 radiator is the one you want. 3 core instead of the 2 core one that is stock for the E36 M3. i have it installed and it fits exactly as before, shroud and everything.
Andrew:
1995: Avus
///Supercharged 95 Club
Installing it sunday:
http://store.bimmerworld.com/e30e36-...tor-p1562.aspx
I'm taking out my mishimoto. It's just over a year old. No problems with it, other than it's not "quite" enough cooling for driving on the racetrack during the summer months. It's for sale if anyone is interested.
Level8Drummer
Driving instructor for: BMWCCA, PCA, SCCA, Chin Motorsports, and Hooked on Driving.
no, i have heard shoddy things about full aluminum radiators, save the full kits from zionsville. so i went with an OEM Z3M S54 radiator, kept the stock thermostat, upgraded to a lower temp fan switch, 50/50 distilled water/bmw coolant, 2 bottles water wetter, stewart water pump, mechanical fan delete, electric spal fan.
you can use your stock shroud, stock expansion tank etc. fits exactly the same
i have had absolutely no issues with the radiator and it will be able to handle anything you throw at it, its a proven design, high quality. I would rather have a proven high quality BMW piece than have to worry about a mushimoto all aluminum radiator or pay the very high price for zionsville or PWR. I was originally dead set on the full competition package from zionsville but in the end decided that i would put that money elsewhere.
Andrew:
1995: Avus
Just ordered one of the Z3s54 rads.
Will be interested to see how the 2 vs. 3 row thing pans-out in terms of cooling.
Garrett
I've got the Bimmerworld kit with the s54 rad, but need to install it and maybe make a DIY...
I need to replace my stock radiator. Can anyone tell me if i'll see improvement with the S54 rad?
Cosmos Schwarz ///M3/4/5...
"MONEY CAN'T BUY TASTE"
I also use the MZ4 S54 unit. Went right in. Have it with a electric fan.
I got it cheaper than bimmerworld though:
http://www.autohausaz.com/search/pro...=2172@Radiator
I could have written the exact same thing. It's EXACTLY what I did and why.
Anyone running a S/C having clearance issues with the 3 row and an electric fan?
Just installed one. It is 4mm deeper than a Mishimoto (44mmvs. 40mm)
The thing was a bitch to bleed for whatever reason. Dunno if I did something wrong or what, but w/ the euro coolant system on my car, it SHOULD have self-bled. Every other rad I've used has self-bled immediately upon filling the euro resevoir. This one trapped a huge stubborn air pocket that almost caused an overheat. Had to crack open the temp switch and overflow nipple to let it pass gas.
Garrett
did the mz3 radiator effect your heater? I could not get any heat during the winter months after I installed the mz3 rad.
Have run the Z3M S54 3 row for 4 years and about 80k. Cooling it outstanding. Never an issue in bumper to bumper 114 degree AC on traffic, or 108 degree autocross at CA speedway. Also run FDM since then. Very happy with that aspect of the car...
When I got mine, only ALU ones where the Zionville and a few others at $500 a pop. Since then lots of cheap ones, but most are cheap and still 2 row. Not seen any real data comparing all the various radiators, something like that could really make it an easy decision.
John
'95 Hellrot M3 w/Dove
AA Euro HFM Stage II (w/21# Injectors & Software) W/Gen III Exhaust - URI Crank Pully - FDM w/3 Row M Coupe Rad - 3.23 LSD - Vogtland Club Spec/Koni SA - UUC Red w/Enforcers - TMS Shims/Rear Camber Bars w/QA1 inners/Sways - VMC F/TMS R End Links - X-Brace - Perf Ultimate/SS Brake Lines - GC Tower Mounts/RTAB Shims - ZKW's w/5000K Hid - Fog Delete - Alpine 9847/Pioneer TS-C130R Kevlar Components/Pioneer PRS-X340/Stealth Box's/Wired Zune 120GB - OE LTW CF Sills/Glove Box Plate - Staggered Black M-Spoke II's w/235/40 (front), 255/40 (Rear) Nitto NT05's - Rolled Fenders!
***Got a '95 M3? (actually pretty common on all years! Even happened to Racer Seth Thomas! ) Check Your LSD! http://forums.bimmerforums.com/forum...d.php?t=390209
