Hello friends, what spark plug used in a e36 328 turbo 1998??
thank you very much
http://www.youtube.com/watch?v=Lxtod...ature=youtu.be
ngk bkr7e stock no 4644
gapped at? well i have mines at .28
gapped between .22 - .28 generally
ok friends NGK BKR7E gapped between .22 - .28 thank you very much
Is yours a european or usa engine?
european
Which turbo you use and what is boost level. Euro 328 is an aluminum block. Built motor or stock?
My turbo is T04E and boost level is 0.7BAR in motor stock
hallo, I have same setup
328i with same turbo
but I have- steel block,forget rods and pistons and 8.5 :1 compress ratio
have anybody here this setup with stock ecu? MS41.0 obd1
Do you use piggiback for setup your engine ? and its fine?
YamirNegrin, did you customize ms41.0 ecu ?
Because, I'm interested in turbo setup for ms41.0
hello friends!
I have used the AEM 301910 and works well but you can use the cam sensor pisicion!
Hello friends!!
We continue to improve gradually. Conversion to OBD1, 0.140 MLS, screws RACEWARE for my M52 aluminum block.
What chips do you recommend to manage my motor?
I really like the miller https://www.millerperformancecars.co...category_id=45
Greetings from Canary Islands
What chips do you recommend to manage my engine?
Please help me!!!!
War?
Hi Yamir,
What questions do you need answered. I see you are on the right path to be able to use the WAR Chip on your car. I would love to get another WAR Chip set up overseas, please let me know what specific questions I can answer.
If you want, we have two full tuning packages. One for pump gas and one that is for high power or use with E85.
The usual tuning package is 1399: https://millerperformancecars.com/ca...category_id=10
The Extreme power package is 1699 and found here: https://millerperformancecars.com/ca...page.tpl&pop=0
Hi!
My questions is.
You can create me a base for my engine. The espesicifaciones are
m52b28 stok pistons with MLS140 and Injectors 450cc (I have)
Is possible use this pack?
699https://millerperformancecars.com/catalogue.html?page=shop.product_details&flypage=f lypage.tpl&product_id=61&category_id=6
thank you very much!!
will have one in canry islands
hello. you know of a company where I can buy the engine sensors for my conversion to OBD1 cam, crank, o2 ... in BOCSH
they can ship to Spain???
thank you very much
thank you very much
hello friends
I have a problem with my CONVERTION to OBD!. When I give the contact, the main relay works but the relay of fuel pump and o2 sensor not working? I have not connected o2 sensor. It may be this the problem?
thank you very much
im loking for studs for my m52 aluminium and i cant find them.
can you give me the reference of those raceware studs?
where i can buy them? if possible in Europe.
best regards
Find me @ Facebook Xpower Andre Pires
The Megasquirt Builder
FWIW NGK 4554's gapped to .20 has worked well for me
haha nvm a little late on that one..
Hi
I'll buy a garrett GT3582R and SPA exhaust manifold for my M52B28.
Which is better with A/R 63 or A/R 82 and T3 or T4 flange?
my goal is between 420-500cv to the wheel.
M52B28 engine aluminum block with 0.140 MLS
