Hey all, my car hasn't had plug wires on it for the past many months, and my bavauto wires finally came in the mail! The only problem is that my distributor cap doesn't have any labels on it to distinguish which cylinder wire goes to which connection!
I know my firing order, I just need to know where to plug them onto the cap
Anyone able to help? Aside from a new battery this is the last step before my car is running again!
1977 320i - BBSs, Recaros, LSD, Zender bits
I have two M10s, but they are both stashed at my place of work. All I have here are M20s. I won't be back to work until Tuesday, and I am sure you don't want to wait that long. However, if you still need it then, I will check for you.
In the meantime, I would think it must be in the Haynes manual somewhere, right? Do you have access to one of those? Or can someone check it out for him?
Tom
SE Connecticut
1982 323i Baur, 1977 320i (carbed),
1978 320i (parts)
1991 325ix 5 speed, 1989 325ix (winter),
1989 325ic (summer)
1973 2002 Malaga (with frosting)
1975 Mercedes W115 300D (The Departed)
the late 1979 323i Euro (project, Now Departed)
Visit my blog: Baurspotting
http://baurspotting.blogspot.com/
BWR PWR!
Hmm, I have a haynes and a chilton but both are packed in boxes in my closet. I will go dig them out, I had forgot about them! Thanks
77 2.0 right? spins clockwise, find top dead center, the rotor will be pointed at number 1, go clock wise 1342.
Page 80 of my 1990 Haynes Manual gives Fig. 4.6 showing the distributor 1-3-4-2 (clockwise) sequence, with #2 located directly above the vacuum advance, or whatever that thing is. . Hope this helps.
Tom
SE Connecticut
1978 320i (parts)
1989 325ic (summer)
BWR PWR!
Thanks, that should be exactly what I need.
My 77 320i Haynes says closest one to the radiator. =)
if only cruz would've seen this when he was wondering why the car would backfire through the intake....
midlifebmw: "E21's always love you, they just let you know who's the boss..."
Spdermnky: "Yes that is a lot of empty wine bottles...its for science."
On a similar note, I've read in a few threads here that the vacuum advance should be facing the front of the car, on the passenger side. Mine is facing the rear of the car on the passenger side, and I was wondering if that really made much of a difference as long as you adjust all of the plug wires 90 degrees.
I timed the car at 2,000rpm and found the ball, but the vacuum advance is pointing in the "wrong" direction. Could this be why my car idles fine, but struggles when revving?
