I own a 2000 740iL
I'm just curious as to whether a faulty Alternator could throw this code?
I've been through 3 batteries in the last three years. I was told by someone that I should put cardboard under the battery to help it not "drain". This I did.
The current symptoms are: The car starts, but doesn't idle smoothly. I can floor the accelerator and the car will idle a little fast.
I tried locating the throttle body to replace it (following the error logic). I was prepared to test the TPS (Throttle Position Sensor), but I've read some posts that suggest that the problem might be something else. And I do seem to remember reading a post that this could happen because of a faulty Alternator
Frustrating.
Zac
P1637 130 Throttle Valve Position Control, Control Deviation
I dont hardly know how it could be related to an alternator....but I guess Ive seen stranger things.
Came across the same fault recently - the problem was that coolant had wicked up the loom that runs from the thermostat housing to the ECU. It looked like this (thanks to Alan for the picture):
Surprisingly, a quick clean of the ECU pins and the connector got it all going again nicely! The long-term fix is to replace the thermostat housing as the heater connection leaks.
My BMW Repair YouTube Channel
Thanks for responding Iceman.
Thanks Timm, I'll trace my ECU down and see if I can clean things up.
I'm on it!
And I'll let you know the results.
Zac
Totally stock 97 740iL except for SatRad
I recently had my ABS unit rebuilt by Module Master. What a great job.
I located the Throttle, but stories about the Torx bolts breaking off have brought me to my knees, I'm hoping that I don't have to go there.
I did have a question. The ABS module is different than the ECU right? (Yeah I know.... I should know that). On my car I'm not sure where that's located.
I took Timm's advice and checked the ECU in the fuse box. It turned out to be a blown 30 amp fuse. Replace the fuse, cleared the error codes and Viola! Obviously I need to figure out why the fuse blew, but man! It's sure good to hear her hum again.
I had to change my battery about 3 times, could've happened during that perhaps.
Thanks for the help Timm and everyone else.
Zac
My pleasure - but you haven't finished yet! The cause of the blown fuse is a faulty heater (or wiring) in the thermostat. And that is usually accompanied by coolant getting into the loom (which is where we started)!
Last edited by zachendricks; 07-30-2011 at 03:04 PM. Reason: Automerged Doublepost
Can someone confirm this?
2000 BMW 740iL | 225,XXX miles | VW MAF | Bavarian Auto Coils | Timing Chain and Guides DIY Complete | M60 Manifold | BDC Polished Throttle Body| Custom Tuned | Performance Gearing 3.46 LSD| Magnaflow mufflers |
|1997 ///M3/2/5 | 104,XXX miles | Boston Green Metallic|2006 X3 3.0 SAV|121,XXX miles| Silver|
What?
Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
Confirm if it was heater or engine thermostat.Originally Posted by Edwin NL
Engine thermostat. Coolant leaks thru the sensor on the thermostat. Shorts the sensor and coolant follows the wiring to the ECU in the fuse box.
