Recently my left side headlight went out of alignment and was pointing too high and blinding oncoming traffic. I don't know how it happened but it did. Here's how you can do it yourself in about 5 mins. I have also seen complaints that the headlights aim too low from the factory and visibility at night is poor.
Pop the hood. The adjustment screw is right behind the headlight module. It looks like this:
I used a flat head screw driver to adjust it. You could also probably use a philips head. Turn it CW to adjust it down and CCW to adjust it up. One full turn is a good sized adjustment so experiment carefully with it.
To check if your headlights are adjusted correctly you can park 25 feet from a wall on a level surface. Measure the distance from the ground to the top of your lights. The cutoff line where they hit on the wall should be no higher than the measurement of your lights. Meaning, if your headlights are two feet off the ground, they shouldnt be shining any higher than 2 feet on the wall. And even if they are that high they will probably be blinding oncoming traffic (they should have a slight downward angle to them).
And if you have an E92 it looks slightly different under there but I don't have any pics of that.
Do you have HIDs?
Current Car (delivered 20/10/21): 2021 G80 M3; 6MT; DravitGrau/Kyalami Orange/Black Extended Merino; Permium Pkg (ZPP); 826M bicolor wheels; Black M Compound brakes; Sunroof (yes no CF roof)
(more pictures here)
Previous Cars: 2018 F30 340ix 6MT Msport(Dec 2017 - Sep 2021); 2013 F30 335ix 6MT Msport (Nov 2013-17); 2011 e90 328i 6MT ZSP (Aug 10-Nov 13); 07 e90-323i ZSP (May 07 - Aug 10); 97-318ti ZSP (Feb 97 - May 07)
"Mit der Dummheit kämpfen Götter selbst vergebens", Friedrich von Schiller -- "Life is simple, people make it complicated", Me (About me)
Can't see the picture, not sure if its just me
2007 328i MT Sedan
I have lazy headlight. Thanks for the info!
Houdini
Do yours adjust automatically? Are you saying that even after they adjust automatically one was off?
Mine seem to level by themselves, not sure how, as sometimes I am parked at an incline so I am not sure how they know they are level. hmm...
I believe the screws still adjust the baseline height for the auto levelling
