So I know many of you have been asking questions about these kits, and deciding whether to get it or not. Well, the answer is YES.
I ended up getting the whole kit for about 500 shipped from gripforce on ebaymotors.
So I was doing a ton of research before doing anything to the car. I found out what kind of parts I needed, what I should replace while in there, what kit to get, etc. So to everyone who still needs help and doesnt feel like researching(your loss), here you go! Just because Im feeling good today.
Sachs Pressure plate
F1 Racing Stage 2 6 sprung hub clutch disk
F1 Racing Stage 2 16 Lightweight Flywheel
Clutch Pedal - 35311158659
Clutch Pivot Pin (steel replacement) - 21511223281
Slave Cylinder - 21521159045 or 21526775924
Throwout Bearing Guide Tube - 23111224845
Throwout Bearing
Clutch Fork Lever - 21511223302
Pressure Plate Bolts (x8)- 07119906045 (I reused my old ones, I felt it was fine, but if your picky get these!)
Flywheel Bolts (x6) - 11222243051
Pilot Bearing - 11211720310
Shifter Parts:
Understeer SSK Kit with modified selector rod and Derlin Bushings
Shift Carrier Arm Bushing (tranny) - 25117507695 (Dont get this if u get the derlin ones from Understeer)
B*tch Clip - 25111221849
Shift Carrier Arm Bushing (chassis) - 25111222015
Shifter Bearing - 25111220600 or 25111469397
Lower Shift Boot - 25111221700
Selector Rod Endlink Clip (2x) - 25117571899
Shift Rod Coupler - 25111222688
Seals: (I didnt do any seals, but I guess its a good idea if you have the money)
Rear Crankshaft Seal - 11141432240
Transmission Output Shaft Seal - 23111224799
Input Shaft Seal - 23211224820
Rear Main Seal - 11142249533
Selector Rod Seal - 23121282394
Exhaust:
18301716888 - Exhaust gaskets, triangle header flange (Asbestos Free) X2
18101405737 - Exhaust gasket, midpipe to catback (Asbestos free) X1
18111723379 - Exhaust gasket, midpipe to catback X1
11621744232 - Exhaust nuts X4
07119912524 - Exhaust bolts X4
I also did the UUC SS Clutch Line, CDV removal, new UUC Clutch arm bushings, and a new Clutch Master and slave cylinder.
Soo..I pretty much did everything clutch related
My guibo looked almost brand new, so I didnt touch that. But if yours looks like shit, replace it by all means.
Heres how it looks:
Now..the process.
1.First, drop the exhaust by removing the nuts from the header area(6) and then remove the hangers from the muffler(2 nuts). and get the midpipe hangers off the car and get the exhaust out.
2.Take off the sound deadening(6 screw/nuts I believe)
3. Drop the driveshaft. I only took off 3 bolts that is held on to the guibo. There are I think 2 or 3 types of bars or cross members under the driveshaft to hold it in place in case something horrible happens, take those off too, just nuts and bolts.
4.Now drop the tranny. This isnt really DIFFICULT if you think about it. i believe there are 9 Fat torx bolts that hold it in place. If you buy E6-E16 sockets, your good to go for the whole car.
Now, the key to removing the tranny is having trouble with the top 2 torx bolts.
This is waht you need, its the magic wand in this operation.
5. Once the tranny is removed, you can do all the shifter parts very easily, and add in all the stuff that goes in the bell housing. Heres what mine looked when I dropped it..horrible!
do the clutch now. Remove the bolts that hold the pressure plate, then the flywheel bolts, replace everything and align it with the alignment tool.
NOW, put everything back in reverse order and your done! took me 3 weeks only working on weekends because i had limited parts available and i was researching at the same time. but about 10 hours of work while eating a ton of sandwiches!
Bleed the clutch after your done, and break in that new baby for about 500 miles with no revs more thatn 4k in my opinion.
I have about 10 miles on the clutch kit and i have no gear noise. everything runs PERFECTLY, and my clutch point is dead on in the middle.
I really hope this helps everyone as everyone has helped me in 2 years of my owning of the m3. Im just giving back now that I know a lot more than I did 2 years ago.
BTW, this is my first clutch job! Feelin soooo accomplished and more together with my m3 now. <3
1999 Cosmos ///M3 | Stromung Exhaust | BBS RXII's 18x8.5 +38 245/35/18 F/R | Bilstein H&R Combo Suspension | Matte Black Front Grill | K&N Air Filter | Front UUC Slotted Rotors | Front Hawk HPS pads | SS lines around | Xenons | Illuminated Shift Knob | Redline 75w-90 Diff | Redline MTL Tranny | Mobil1 10w-30 Engine |5mm Spacer Front | SS Clutch Line
Great work, I'm loving ur list of parts as I'm just starting to accumulate all I can for this job. So far I think the only extras I'm gonna add are the detents and a flex disc.
Bump. Thanks for the support guys..
good work
how is the pedal feel with this stage2 clutch?
How is the clutch grabbing feel compared to stock parts?
you need gear pullers and stuff to replace the TO-bearing?
-Rich-
AWESOME job man!
Reading your review will definitely help a lot of guys change their heavy noisy flywheel for a better one.
Feel any performance boost from the lighter flywheel?
Current:
1983 E21 320I ''Trusty stead!'' Ireland engineering suspension, solid strut bar, all stock
1995 E36 ///M3 ''Could it be love? it is!'' so Much $$$$$ Dumped on this car!
2002 E39 ///M5 ''Angry little thing!'' dinan tune, dinan diff, supersprint exhaust system overhaul...
The goners:
1992 E30 318is slicktop ''Knuckles'' volvo lip, full stock
1992 E36 320i ''You did good little one'' Full stock
1988 w124 Mercedes 250d ''Best car ever...EVER!'' Bone stock!
Whatever you can ''faster'', I can do ''faster''!
updates?
Looks like an OEM flywheel with holes drilled out of it. You get what you pay for
I've heard great things about these clutches and will be putting mine in soon
[2.25" Magnaflow][3.38 LSD][GC Track/School][3.5" HFM][Cosmos V2 + Tuning][UUC Sway Bars][UUC Subframe Bushings, RTAB, RSM w/ Plates, Trans. Mounts][X-Brace][Brembos]
Mine failed after a few thousand miles probably hit and miss as some owners have had great results.
I've been using the Stage 4 clutch flywheel combo for about 6k miles now and no complaints
my .02 is cheap and effective product. would buy again
aa supercharger 11psi, F1 Racing Stage 4 Clutch, Fidanza 13lb flywheel, Bilstein shocks w/ HR Race, header back 3in exhaust, evo style front lip, Depo's w/ angel eyes
its been 1200 miles. update:
solid as hell. I hear no gearbox noise at all, revs much faster in 1st and 2nd.
no problems at all.
whoever is still considering. GET IT.
another +1 for gripforce racing!! i got a 14.45 lb LTW fly (exactly as they stated on their ads), flywheel bolts, Sachs organic clutch, Sachs pressure plate, Sachs throw-out bearing and clutch alignment tool for the killer price of $448 shipped!!
LTW fly weighing in at 14.45LBs (exactly what they stated)...flywheel bolts were 0.85LBs
Sachs clutch + pressure plate: 14.10LBs
so altogether, 29.4LB rotational mass with the new kit...the stock setup is like a 30lb (95 M3) dual mass flywheel + approx 14lb clutch/pp coming to a toal of about 44lbs. approx -14.6LBs sounds good to me
Element Tuning - 2008/2009 NJMP Redline Time Attack/Formula X Champions [Street & Modified]
RightFootDown
FS: E36 OEM fogs | UUC Chromoly RLCA's
What is that "magic wand" that you talk of?
a bunch of extensions in 1/4".
The picture is above. When you see it, you'll see it.
BF.c, where dudes talk with other dudes about gauges.
THats brilliant, so just undo the driveshaft and use a lots of 1/4th extensions to take the top torx out?
I have a 30" long 1/2" drive extension that I use for that. Much easier to apply breakaway torque with it than using a 3/8".
Neil
any updates on this clutch kit?
No problems at all as of yet, and its been a while too. im currently at 162k.
the only problem is the throw out bearing went out...soooo pissed about that.
when i clutch in no noise, but clutch out and theres noise, and only when its warmed up thoroughly.
Other than that, greatttt buy!
