My BMW just started overheating. It doesn't do it on the interstate or when driving. It only does it when it is at a stop light.
I replaced the thermostat in it a few months ago, and flushed the cooling system while doing that.
I got an error code as well: P0441 - EVAP no purge flow detected
Seems unrelated, but the only thing I noticed that could be wrong is the electric fan doesn't spin. Other than that every thing seems fine. Thermostat isn't that old, Mechanical fan is working, coolant level is good.
What could be the problem?
When doing cooling work--it's a given to do all of the parts at one time--when one goes the others are sure to follow--my guess on which one is giving trouble at this point would be the fan clutch--your sure you bled the cooling system correctly
- Likely bad Fan Clutch.
- In your cooling system, anything not yet replaced in the cooling system ---> replace them ASAP. A few episodes of overheat and you are in for a much more expensive repair $3000-4000!
- Here is the DIY for 1998 528i I wrote back in 2006 (Edit: do not use MTC Fan Blade, use Dealer Fan Blade only):
http://www.bimmerboard.com/forums/posts/199986
could be the clutch but could also be an air bubble in the system (that was my problem). Agree - don't let that baby O/H.....
Here is something interesting.
1. When driving the cars temp is ideal.
2. When at a stop light the car starts to heat up.
1. When driving the car blows heat w/ the heater on.
2. When at a stop light the car blows cold w/ the heater on.
This is puzzling to me. I though it had something to do with the engines RPMs. So I stopped in a parking lot. Let it idle till the temperature started to go up. I rev'd the engine to 2000 RPM and held it there. The engine heated up faster.
air bubbles are scary, when I was working on my cooling system that is one thing i worked hard to make sure didn't happen...
I also + 1 on the bleeding. . check for air bubbles. . . I had this problem once and got the thermostat changed and the housing. . exactly 1 week later it did it again, ONLY when I was stopped, , then ended up checking for airbubles, and BELIEVE IT OR NOT I changed the thermostat again, and the problem went away. . .
But number 1 thing is to bleed the system, and make 100% sure that isn't the problem
do not screw around with it take it to a shop.
I bleed it when I first redid the thermostat. I could try it again, but I don't think that explains this.
http://forums.bimmerforums.com/forum...26&postcount=5
Actually it may very well explain it. try this bleeding procedure it may save you a lot of cost and frustration. worst case it cost you 10 minutes.
http://forums.bimmerforums.com/forum...post&t=1423821
many with similar issues to yours have successfully fixed them after following those instructions, give it a shot.
>'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
I agree that you should bleed the system thoroughly again, it costs virtually nothing.
However, for the next few weeks/months, keep very close eyes on the coolant level and engine temp gauge. It does not take much to warp the cyl head or blow a head gasket (now it is $3000-4000 to fix).
As I mentioned above, if you have more than 100K, do a cooling overhaul. Any parts you already replaced, keep them, any part(s) with more than 100K, replace them.
Thanks guys. I will definitely try this today.
I'm not really interested in doing a cooling system overhaul, because I plan on replacing the engine with either an L47 or LS1 over the summer. I just need to keep this engine alive long enough to do that
2001 540i/6 - 144k
1997 328 ic - 67k
hardtop
2008 328i 6spd 88k
2008 328i 84k auto
1998 328i sedan 5 speed - 190k RIP
1995 325i sedan - Hellrot - 124k RIP
You're going to put an engine for an old's Aurora in your BMW?
[ame]http://en.wikipedia.org/wiki/Northstar_engine_series[/ame]
Yeah, I think thats a great engine. It's 100 percent aluminum, and a Indy version of it was tuned to 650 horse power, naturally aspirated. Plus I see Aurora's with bad transmissions or have been wrecked go for 500-1000 dollars.
It turns on with the AC. So I guess it does work.this clearly indicates air in the system, but you may also have a bad fan clutch. Does the auxillary fan come on when you turn the AC on?
Bleeding the coolant seems to have fixed the problem. It blows warm air at idle, and doesn't overheat.
Only I think it's too late to avoid damage.
Here is a sound that it's making. It sounds like a diesel or nocking sound from the cylinder closest to the bumper. Not sure how the I6 is numbered.
Don't turn it up too loud, I rev the engine to 2500 twice somewhere in the middle.
http://xeniczone.com/BMWI6528.m4a
Bleed the cooling system. This had me dumbfounded for months. Only to find out there's a proper way of bleeding the cooling system. See the section on Bleeding the Cooling System on this PDF: http://www.bavauto.com/newsletter/20...ter.pdf#page=3
Actually it is this procedure that has caused many here so much trouble, for certain BMWs the above process works well but for the e39 it seems to cause as many issues as it solves. The cold bleeding procedure posted above has proven to be very straightforward and has a near perfect success rate. Thanks for the info.
