Page 1 of 4 1234 LastLast
Results 1 to 25 of 89
Thread: E38 Bi-Xenon! headlight installation in stock headlight assembly!!PIC WARNING! UPD!
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    OK here we go!
    First off tnx to Pavel for the push to just do it!
    The projector lens
    Old vs NEW
    Take the headlight out of the car (see E38.org)
    Remove the weather strip
    Flip over and undo the 3 T20 screws
    Slide out
    Use a screwdriver to remove the clips
    Remove the cover of the xenon
    Back view
    Use a screwdriver to pry both headlight adjusters off
    Remove the headlight cover
    Remove the screw in the corner
    Remove cover and you see this
    Use a pair of pliers to pinch the center so it pops (headlight adjuster)
    Unplug the highbeam
    Remove the ground wire
    Remove the tabs (front and rear) yo remove the center piece
    Now you see the back screws
    Not sure what you call these (inverted torx?)
    Undo all 3
    Pull the lens straight out
    Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    Empty housing
    The major difference in lens size!
    But just as long!
    Only one is marked RIGHT!
    Nice and full!
    When test fitting you can encounter the motor to hit the housing
    I removed a little
    The holes in the lens
    The screw size
    Drilled the holes a little bigger
    Nice a tight fit!
    Made them a little bigger for better adjustment
    Align it correct!!!
    Headlight without cover
    With cover
    The cover does not fit so we need to grind a little to make room
    After I'm done
    Nice and tight and does not touch
    In place
    Reconnect the ground wire
    Gently slide it back in!!!
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    My projector was hitting the inside of the housing
    So removed a little extra metal
    Installed
    Solder the wires (extend them)
    And connect them to the brown (ground wire) and the white from the high beam light
    But it back together and install in the car!
    Here a new and old headlight!
    New
    Old
    All done
    And the AWESOME video
    [ame]http://www.youtube.com/watch?v=WGadPVW3UWk[/ame]
    Do not think of this mod lightly!
    It took me 9 hours to get them perfect!
    SELLER INFO:
    http://myworld.ebay.com/ebaymotors/factory_xenon/
    His name is Mike and ships the same day and has an excellent after sales!
    Ireland
    2005 E66 740Li
    Nice job! What are the bi-xenons from, a 2007 E65?
    Oct 2007
    Dallas, TX
    740is
    sweet man. thats an excellent mod.
    Jacksonville,fl
    Imola740i, turbo eclipse
    Did you notice a significant improvement in low beam output? I have Acura tax projectors in my eclipse and they have much better output and cutoff compared to the oem e38 projectors, I was really unimpressed with the oem xenons. I think I might be switching them out for my Acura lenses.
    Toronto, Canada
    2000 740iL - 07/99
    When I saw bi-xenon, I thought you would be retrofitting the existing xenons from the low beams into the high beam location. THAT would be awesome!
    Great Mod none-the-less
    Follow me on Instagram @SEVEN40iL
    Feb 2009
    USA
    S500, E320
    How much?
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    Quote Originally Posted by Jamesbond740il View Post
    Dude did you see the video at all???????
    Quote Originally Posted by SEVEN40iL View Post
    This is Bi-Xenon buddy
    Quote Originally Posted by bstar View Post
    How much?
    You got whatsapp
    Apr 2009
    Lorton VA
    E38 740 iL
    whoa... sick conversion edwin. I like how the new projector eliminates the gap between internal lenses and projector it self. Looks like it's meant to be that way. Where did you find the projector btw?
    Oh, one more question.. I want to swap out my existing projectors to more crystal clear ones. Is there any out there that can fit? If so what are the size of oem projectors?
    Oct 2008
    Easton, pa
    00 740il (Its Long)
    NICE, 9 hours to do, you could have done it in 5 if you wasn't taking pics and stuff.
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    5 is not possible!
    The first took me 5 hours and today 4
    Jacksonville,fl
    Man just watched the vid, and now I'm sure it wasn't just me, oem e38 projectors suck badly. Looks like I know what I'm doin Tom. Hopefully it'll go smooth. Now I wish I hadn't given away my bixenon projectors I had laying around.
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    New night video coming up
    Nov 2008
    Amsterdam NL
    735i 2001 E38
    Night time video
    [ame]http://www.youtube.com/watch?v=lyP1rHoHnN0[/ame]
    Apr 2009
    Long Island NY
    95 e38 2002 e46
    Great Mod but you missed a spot..........................
    When you get to NY I will show you!
    Mar 2010
    McPherson, KS
    2000 BMW 750iL
    Cool mod...another great writeup! Nice choice of background music btw .
    Nov 2002
    York, PA
    2000 740i Sport
    Very cool
    Are you willing to convert other peoples' housings for a fee if they ship to you?
    Toronto, Canada
    2000 740iL - 07/99
    Quote Originally Posted by Strahan View Post
    Very cool
    This. Is a great idea!
    Franklin, Va
    01 750 Sport "Angel"
    Pre-face lift cars can also be converted.. This is a very Awesome mod!!! I do quite a bit of night driving and these make the trip alittle more enjoyable..
    Very cool
    Lol.. Just have to find someone in the states that is pretty close to you that has also done this mod..
    Avenging Angel: 2001 750iL Sport Schwartz II Metallic, too many upgrades to list here..
    Kirsa: 2000 750iL Biarritz Blau Metallic, Born on 11/99. Sold 12/21/13
    The Mistress: 1997 744iL Biarritz Blau Metallic, Sold 6/7/12. You will be missed Baby..
    Mar 2008
    PA
    2001 E38
    Gutsiest move I've ever seen Mav. Would those be the Hella 3" E55's?
    2001 740iL BI-XENON 3" Projectors LED AE's. Clear corners. EuroDyne tails. Bilstien S&S / H&R Stage 2 springs. Widescreen/Mark4 DVD. Escort 9500ci Radar/Laser.Beyern 19" Multi's staggered.
    Franklin, Va
    Hella 3" are in the E55's as well as the M5's..
    Nov 2008
    Montreal, QC, Canada
    2001 740i Sport
    very impressive.
    As usual.
    Mar 2008
    PA
    2001 E38
    Quote Originally Posted by Chief Jimbo View Post
    So I take it that's a +1 on the fit? Pricing seems reasonable.
    Franklin, Va
    Quote Originally Posted by Zorack View Post
    I had a couple extra issues because I have the preface lift light housings but the fit was still real good! My only issue is that the back lens covers do not fit because the D2S HID set up is bigger then the originals.. But working on a work around..
