I was wondering if anyone on here has rebuilt a starter on a m50 motor.
I have been having trouble with my starter acting up. It sounds like the brushes are starting to fail and possibly the bearings. I would GREATLY appreciate any help on this. I can't really afford a new starter at the moment. I just had to put a drivers door on my car so that was my car money for the month.
I've done it on a m20 before it was just a case of stripping it down and replacing the bushes but I'm sure some one can help you on here or point you in the right direction.
It may not only be the brushes, I took apart a M70 starter, and found a lot of cracked plastic
motor starter with plastic planetary gear broken
http://www.bimmerboard.com/forums/posts/643922/
it works no again, took the planetary gear from a Mercedes Benz starter which is basically the same except the one toothed wheel, works perfect, now a mix of BMW/Benz Bosch starter
thanks for the links on the starter motor R&R's. I might just have to do that but I need to have parts ready and waiting if and when I rebuild it.
Is there some where I can get a rebuild kit for it?
