Check your boot before the MAF.
99 Alpine/Gutted ///M3
98 Estoril/M-Technic cloth ///M3
- RIP http://forums.bimmerforums.com/forum....php?t=1191513
ahh
replace that shit hose with this: magnum vac hose.
http://www.boostcontroller.com/index.php?category=212
Motor: Hurtig/AA custom 2.0l TS OBD2 AA tuned 444whp/384wtq SAE 470whp/400wtq STD
Exhaust RMS headers, Maximum PSI custom exhaust, magnaflow mufflers
Driveline E46 M3 6 SPEED, 2.93 LSD, Rouge SSK/tranny mounts, UUC Ultrasmooth /LTW steel flywheel. CDV delete, UUC clutch pedal bushings with GSP pedal
COOLING: Stewart WP, 78* thermostat, S54 radiator, Euro/S54 oil cooler, ES TS oil cooler adapter, M3 power steering cooler
HANDLING: MR M CAR SF reinforcement, TCK D/A CO 450/500, TCK Camber Plates, Rogue RSM, Ireland SFB, Dinan STB. CCW classics, polished lip, brushed centers. P295/30/18 P245/35/18.
THE SHOW: Stygar Z8 Nozzels, Leather Z armrest, Z8 push button start, chrome door handles, OEM FOGS, BMW Traffic Pro.
Monitoring: PLX Wideband, VDO vision boost/VAC both with custom chrome trim ring.
COMING SOON: custom intake
I ended up tracking my idling issues to two separate problems.
1) The infamous, coolant-looking hose with internal spring to keep it from collapsing, looked like a vertical pancake when my car was at idle. Luckily upon further examination, my hose was not punctured. However, the spring itself had shifted towards one end of the hose. I ended up "stretching out" the spring within the hose then used zip ties at 1 inch intervals on the outside of the hose. Hopefully, this will prevent the spring from shifting. I also shaved the sharp ends of the spring down.
2) The hose to the oil/cyclone separator (located at the very bottom of the TS) had it's hose slip off. The problem was that this hose is located fairly deep within the underbelly of the TS and the only way I could see it was after I put my car on a lift.
JMC: Thanks for the link. The Magnum hose appears only available up to an ID of 3/4". I believe that that company doesn't make anything as large as an ID 1.5" which is currently on the Eurosport TS cars.
97 ///M3 Turbo Saloon
VEHICLE: TRM Tuning Turbo System | Built Engine | SwainTech coatings | Custom 3.5" exhaust | Cryo Treated 210mm 3.15 Diff w/40% lock-up | 420G 6-speed transmission | UUC Twin Disc clutch | AMS-500 | AST Suspension | AP Racing | Racelogic TC | Dr. Vanos | Riot Racing BBTB | Vorshlag | UUC | AA | JT Design | Recaro | SPA Technique | VDO | Raid | Turner | Castillo Design FXR Retrofits | Zionsville Autosport | Stewart Components | Motion Motorsport underpanel | Z3 steering rack retrofit | Billet throttle body bushings
SOUND: Pioneer DEX-P99RS | Dynaudio | Morel | Image Dynamics | Arc Audio | JL Audio | Audio Control
OTHER: AEM Wideband Failsafe gauge | Ecliptech | Escort 9500Ci | LI | Hüper Optik | Llumar Air Blue | Skene Design
PHOTOS: Engine Bay: Click
Any updates on what hose people used in the ES TS? Mine is collapsing already.
update: Thanks to WK446 (Dennis) for sharing his fix. Aside from the vac hose with the spring in it (which remains a potential problem, but I have a 1.5" samco hose on order to replace it), there was a second LARGE Vac leak I discovered, repaired for $9 and the idle hunting is gone. what's more, she is more responsive.
The large hose leak was along the underside of the hose shown below (just downstream from MAF), where a stock BMW intake (#13 54 1 438 761) was modified to accept another hose, basically cutting out a segment of that hose and gluing in a rubber seal with with a second port on it, to which a another hose attaches. The adhesive had broken down and was creating a large gash through which air leaked in (after the MAF). Since its underneath, it's not visible until you remove the hose and inspect it. If you have fiddled around with the system, you may have torqued/lossened the seal, plus its immediately below the TS oil vent exhaust tube so the oils over time may degrade the glue.
I cleaned up the glue and reattached with 3M superweather gasket sealant pn #8008 and voila, fixed. Took me less than 45 minutes total (except for glue setting overnight). If your donor hose is shot, you can also replace the BMW intake hose (13 54 1 438 761) too (WK446 did). pic below shows Dennis' old intake hose (you can see the tranplanted port was remnoved) next to his replacement new hose before he modified it to accept the transplant port (not shown).
Anyway, Idle hunting is GONE, and as a bonus she pulls like a FIEND, definitely more responsive.
THANKS TO DENNIS!
'99 Hellrot M3 vert; Eurosport twin-screw SC w/ 76mm pulley + Schrick cam (i.e., TRM Stage 2 TS), UDP's,
oil cooler; GC coilovers; Z3 steering rack; Euro 6-spd trans; Diffsonline 3.46 LSD
Thats what i told you to check months ago silly!!!!!!!
Kinda (I said before the maf, my bad)
Yeah, I had the same issue.
Superglue it and then do burnouts.
my bad for not listening. i suck
